Hardware Computex 2014 - Day 1
Discussion in 'Article Discussion' started by Dogbert666, 4 Jun 2014.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Dude, the Steam Castle case is SO NOT steampunk.
  3. Hustler
    Hustler Minimodder
    8 Aug 2005
    Strangely, I rather like those Deepcool cases and I don't normally go in for such ostentatious styling....definitely agree the rubberised finish is superior.
    I'd also like to know if those side vents and top fan covers are removable, should you want to bust out the Plasti-kote for a custom colour paint job.
  4. Almightyrastus
    Almightyrastus On the jazz.
    21 Mar 2002
    I'd go more with dieselpunk if I had to pigeon hole them. Could look interesting with a polished / satin metal finish through.
  5. David
    7 Apr 2009
    That Deepcool chassis is hideous - were they expecting to appeal to 11 year olds?
  6. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    I like the P380 Antec case.
  7. Combatus
    16 Feb 2009
    Ha ha! I'd say funky rather than hideous ;) The Raijintek Metis looks gorgeous though, but not sure about airflow... Either way, looking forward to getting those two in the lab for testing :D
  8. montymole
    montymole Rigid Tubist
    24 May 2010
    the Deepcool one is using the same oem internals as the Aerocool DS and the Xigmatek aquila i thought as much from the 1st glance the other day
  9. montymole
    24 May 2010
    The Metis looks very nice but as Combatus said its the lack or airflow but for small media pc hmmmm
  10. Nexxo
    23 Oct 2001
    None of the cases inspire me. They look hideously inelegant.
  11. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    The Deepcool case would be a nightmare to clean, i wouldn't fancy having to use cotton buds to clean in all the nooks and crannies.
    I love the look of the Raijintek Metis, it would look right at home in the living room, or alongside some AV equipment, under the TV. There AIO cooler also looks great, along with being able to change fluids and top it up.
  12. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    I am really interested in the direction Raijintek has taken with it's AIO. When thinking of water cooling (which is going to be what I use when I build a new system when high end Maxwell GPUs are launched) I have been caught between using an AIO and trying a full custom loop. I want the visuals of the custom loop but with the ease of an AIO, as such the Raijintek looks to tick all boxes. Maybe this will also force Corsair and others to do likewise. I know some have adapted current AIOs to use clear tubing and coloured coolant, but that is taking things in to your own hands and as an inexperienced water-cooler, it is more than I think is sensible for me to do.
  13. vajoiner
    vajoiner What's a Dremel?
    25 Apr 2014
    on my personal keyboard rating system :) the aorus is the first keyboard to hit a speculative 9/10. so.. damn.. close.
    +1 mechanical, +1 tenkeyless, +1 keeping numeric key functionality, +1 macros, +1 non overly aggressive styling, +1 optional wristpad, +1 headphone jack, +1 volume wheel, +1 of 2 backlit (+0 rgb and zones)
    a 11/10 for me would be wireless/wired (phone jack and backlighting issues i suppose)
    the second (i just saw) to make 9/10 is the corsair vengeance k95. missing tenkeyless
  14. Impatience
    Impatience Minimodder
    6 Apr 2014
    This. I'm using a modded H60 (clear tubing and mayhems pastel orange, to match my current build) AIO, but it's a big issue if you want anything else.. Because nothing is compatible with a custom loop! (For the record, the "new" square H60 uses 6mm tubing, which is impossible to find barbs or tubing for it would seem! :duh:)
  15. Combatus
    16 Feb 2009
    I used 6/8mm tubing and compression fittings to mod an H60 a while back and added a bay reservoir
    http://www.aquatuning.co.uk/index.php/cPath/50/XTCsid/6aavpt7jmni99kk9eaov9bge91
  16. Impatience
    6 Apr 2014
    @Combatus How did I not see that when I was looking for parts?! Ahh, it's labelled 8/6.. I was expecting a 6/8 like other sites I looked on! :duh: I dont get why they've labelled it as 8/6mm (6x1) though.. What's with the 6x1?
  17. SchizoFrog
    5 May 2009
    Maybe I'll hit the forum for advice/guide to modding a Corsair H100i with clear tubing, coloured coolant and possibly adding in a small res (res - mainly for aesthetics as I think res's look cool).
  18. Combatus
    16 Feb 2009
    Have no idea what the 6x1 bit is - maybe internal diameter and wall or something! Definitely works though!
  19. SchizoFrog
    5 May 2009
    I think 6x1mm is the screw thread count. 6 rotations x 1mm spacing.
  20. Almightyrastus
    21 Mar 2002
    1mm is the standard pitch for an M6 thread
Tags: Add Tags
