Electronics Conductivity of CDs?
Discussion in 'Modding' started by ev0lution, 8 Jan 2005.
  1. ev0lution
    ev0lution What's a Dremel?
    21 Dec 2004
    Im not sure if this is the right place for this question, if not then please can you move it to a more appropriate place.
    Does the shiny part of CDs conduct electricity? I want to glue a few cds together to make a thickish round circle, and mount a number of bloo leds on the top so that the shiny part of the cds will act kind of like a light shade and focus the light in the direction its facing. :dremel: Will this plan work or is the shiny layer of the cd going to create a short and blow my PSU up?
  2. kergareth
    kergareth Minimodder
    6 Jul 2004
    They should, but probably not too much ('cause the foil layer is so thin). However, if you run the current through multiple cd's it should be ok. To minimise the number of cd's, you could cut a thin-ish line (with a dremel of something else) down the middle of the cd to seperate the foil into suitable conductors for the + current and the - current. Attaching the power source to the foil might be a problem though.
    Cool idea though :D. Will try it if that's ok with you. My room needs new lighting anyways :)
  3. Feline
    Feline What's a Dremel?
    17 Dec 2004
    Put a CD in the microwave for 30 seconds....and you will discover that, yes, they do in fact conduct electricity.
    Actually, it looks really cool, but it smells horrible.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The aluminium layer is sandwiched between two plastic coats, so the metal surface isn't exposed. Otherwise the slightest scratch would mess them up.
  5. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    You only need to put the CD in the microwave for 1 second.
  6. Snood
    Snood What's a Dremel?
    27 Feb 2003
    30 seconds and you have a broken microwave, a stinking kitchen and a CD burnt to the microwave turntable.
    :hehe:
    Snood
  7. bigal
    bigal Fetch n Execute
    8 Oct 2004
    no they dont... (just checked)
    BTW: anyone ever put a grape or a bar of soap in a microwave? :confused:
    sopposed to be effective...
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Bet they're not as effective as an egg... :blush:
  9. ev0lution
    21 Dec 2004
    Hmm, I guess thats plan B then :wallbash: I wasn't going to use the layers of (aluminium?) inside the cds to power the circuit, I was just going to use the CDs as a mounting board for the LEDs. I suppose if I made sure the wires going through the holes were properly covered in heatshrink that it would work ok. I think I will give it a miss now though as one small piece of bare wire touching the aluminium would fry the psu. :sigh: I think ill just use a cheap pice of plywood and some of those (expensive looking) chrome led holders then.
  10. mottl3y
    mottl3y What's a Dremel?
    1 Nov 2004
    you could always run the cabling through the hole in the centre of all the cds (if theyre lined up)
  11. Snood
    27 Feb 2003
    you could drill the hole slightly witer then the individual led legs, then place a blob of a clear laquer/varnish over the hole and let it run through to seal the sides (and the aluminium) and if surface tension stops it from flowing thru.... use a vaccum cleaner to suck the laquer through the hole...... it's kinda the reverse of thru-hole pcbs lol.
    Snood
  12. nohope4me
    nohope4me What's a Dremel?
    2 Jun 2004
  13. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    mine takes 5 sec to light up, and after around 7 secs all you get is a bad smell.
  14. kergareth
    6 Jul 2004
    Isn't that only for dvd's? Unless it's a really thin layer on the top.
  15. cpemma
    cpemma Ecky thump
    27 Nov 2001
    CD - Plastic disc stamped with pit pattern on one side; same side vacuum-coated with aluminium to make surface more reflective/more contrast between pits & land; aluminium spin-coated with a thin plastic resin laquer; laquered side printed with label.
    CD-R are basically similar, but plastic disc coated with laser-reactive dye, then often a gold film, then thin resin on label side. In both cases the label side is easiest to cause damage on, hence don't write on CD-R with a hard-tipped pen or nasty solvent inks.
  16. Wrigley1
    Wrigley1 What's a Dremel?
    5 Dec 2004
    For future notice mate, just take a battery tester, set it to 1K ohms, and touch the ends to the CD. Or whatever else you are testing. battery testers... useful stuff. :thumb:
  17. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    Nope, Mythbusters busted that one.. :)
    cpemma, Eggs are always fun.. Nuke one a little bit (don't let it eggsplode and dare a friend to take it out of the microwave.. They practically eggsplode on contact.. :)
    Anyway, I doubt the foil layer in a cd would be a good conductor. Better off running a small wire or something..
  18. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    Erm... you do know that "horrible smell" is cyanide right? Be carefull you dont kill yourself
  19. Wolfe
    7 Sep 2003
    Where the heck did you hear that?!?!?!?!
    it's the same smell you get when you burn polycarbonate, which is what cds are made of.
    Incidentally, i have a bridge to sell you.
  20. Snood
    27 Feb 2003
    LOL..... you really think they would put cyanide in a product which comes into contact with people directly... next i suppose you'll say theres arsenic in printer cartirdges..
    Snood
