Conduit Help
Discussion in 'General' started by Guest-2867, 28 Jun 2006.
  1. Guest-2867
    Guest-2867 Guest
    Hi,
    I'm currently gutting and re-wiring the computer room and i'm after a specific type of conduit to keep things nice and neat. It's like a big white bar that you can mount on the wall, to which you can mount sockets on and run all the wires through it nice and neat :)
    Anyone know the proper name for it? I know you can get it because you see it in most businesses, but I can't seem to get the right name, even a few googles for different types of conduit have turned up nothing :(
    Cheers for any help in advance :thumb:
  2. ch424
    ch424 Design Warrior
    26 May 2004
    You mean trunking?
  3. Guest-2867
    Guest-2867 Guest
    Yes that's the fellow :)
    Any idea where I couldd get it, had a look round screwfix's site but I can only find tiny sizes :D
  4. GaviN
    GaviN What's a Dremel?
    19 Mar 2001
    Proper electrical whole salers?
  5. Guest-2867
    Guest-2867 Guest
  6. fev
    fev Industry Fallout
    13 Aug 2003
  7. Pal_Mal
    Pal_Mal What's a Dremel?
    30 Jun 2005
    I can recommend TLC electrical - get loads of bits from them
    you can also try QVS
    http://www.qvsdirect.co.uk/
    Similar to TLC , but I find TLC better
  8. Guest-2867
    Guest-2867 Guest
    Awesome Guys, Cheers :thumb:
