Confused about hardware choices....help!
Discussion in 'Hardware' started by Fraze, 4 Apr 2008.
  1. Fraze
    Fraze Minimodder
    16 Feb 2002
    komplett do a number of bundle upgrade kits, and with the hardware i'm looking at buying one of these would actually be a bit cheaper for me....
    but which of the following is better? and is the equipment in the kits actually properly matched?? i'm very confused :S
    http://www.komplett.co.uk/k/ki.aspx?sku=343860 - £189
    AMD Athlon 64 X2 6000+ 3.0GHz Socket AM2 2MB, BOXED w/fan
    MSI K9N NEO-F V3, nForce 560, Socket-AM2 ,SATAII, DDR2, GbLAN, ATX, PCI-Ex16
    OCZ Gold XTC DDR2 PC6400 4096MB KIT, w/two 2048MB PC6400 XTC, CL5
    http://www.komplett.co.uk/k/ki.aspx?sku=343653 - £205
    Intel Core 2 Duo E6750 2.67GHz 1333Mhz Socket LGA775, 4MB, BOXED w/fan
    Gigabyte GA-EP35-DS3, P35, Socket-775, ATX, GbLAN, DDR2, ICH9, DES, PCI-Ex16
    A-DATA DDR2 PC5300 2048MB CL5 Kit w/two matched DDR2 667 1024MB CL5
    i'm leaning towards the Intel kit, but am concerned that the memory is mis-matched - as i see everyone with memory of 6400 speeds and above in the PC specs.....
    Any help would be greatly appreciated!
  2. CobraMods
    CobraMods Gettin there slowly
    28 Mar 2008
    your not really saving much there to be honest
    a quick run through scans products and upgrading to corsair memory instead of A-Data brought me within £5 of thier offer. i would personally go a step further and put the quickest memory you could afford into it instead of wasting money on slower stuff you may not be happy with even a year from now.
    LN19275
    Intel Core 2 Duo E6750, Conroe Core, S775, 2.66 GHz, 1333MHz FSB, 4MB Cache, Retail £101.79
    LN21759
    Gigabyte EP35-DS3P, iP35, S 775, PCI-E (x16), DDR2 1066/667/800/1200 MHz, SATA II, SATA RAID, ATX £85.00
    LN12200
    2GB (2x1GB) Corsair TwinX XMS2, DDR2 PC2-5400 (667), 240 Pin, Non-ECC Unbuffered, CAS 4-4-4-12 £23.54
    £210.33 total +VAT and carriage
  3. Fraze
    Fraze Minimodder
    16 Feb 2002
    would it not be more prudent to spec 6400 memoiry rather than 5300 though...have to admit i'm a bit out of touch with current FSB/Mem interfaces speeds.
    i just specced up somehting on scan for £215 inc vat that has 2gb 6400 memory
  4. Rege
    Rege What's a Dremel?
    24 Mar 2008
    Go fo 6400. ATM the best price/performance ratio IMHO.
