Electronics Connect 7" Screen (Touch) - Which/How ?
Discussion in 'Modding' started by Fonne, 14 Jun 2012.
  1. Fonne
    Fonne What's a Dremel?
    9 Oct 2010
    Hi
    Planning my casebuild, and is looking at mounting a 7" screen (Touch would be lovely - 4,3" could maybe work ) ...
    Is going to be a secodary screen, showing a moving when playing, or something like that.
    Is the most easy to buy a cheap Tablet, and take apart ? - Going to use a Asus Z77 motherboard.
    Hope you see where im going - What to search on ebay for ? :D
    Regards Henrik
  2. bluc
    bluc What's a Dremel?
    4 Apr 2012
  3. Fonne
    9 Oct 2010
  4. Fonne
    9 Oct 2010
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    You might as well forget about this option as there are not VGA/DVI/HDMI pin outs inside such devices that could be used to connect to.
    You need the matching controller chip for the screen to make it work, and you don't know if that chip could be hacked until you take the device apart. Then if it's not got a usable controller you've got an expensive paperweight.
  6. Fonne
    9 Oct 2010
    Already forgotton :-D ....
    Lilliput looks like the thing im searcing for, going to order it next payday ... Was hoping at something thinner, but will be taking it apart, and see how big it really is ...
  7. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    I'm not quite sure what you were looking to spend, but I used a SoundGraph FingerUI 700M in my Music Box build. Quite happy with the screen
    7" Touchscreen, and 25mm thick. Powered by an adapter from the 24-pin motherboard connector, and has internal USB header for video connection. It also came with a few other things to plug in such as IR receiver, the button board, and button/wheel combo thing:
    http://www.soundgraph.com/oem-fingervu700m-feature-en/
  8. Fonne
    9 Oct 2010
    That almost the same size as the Lilliput
    http://www.lilliputweb.net/index.php?Controller=User_Product&action=ShowProduct&product_id=88#Key
    Dimension(LWH):188×123×23.5mm/25.8mm(with touch panel)
    In my build that just pretty big :-( ....
    Just hate that you can get at much thinner tablet for the same price, with hardware ...
    http://www.ebay.de/itm/HYUNDAI-A7HD...50925070?pt=Laptops_Nov05&hash=item27c7823a0e
    All Winner A10: 1.0GHz, Cortex-A8; GPU: Mali-400
    Display: IPS
    Resolution: 1024 x 600px, 169ppi
    Product Size: 174 x 118 x 8.9mm
    Come on, better screen, nice hardware and thinner = cost the same :-S ....
