HTPC Connect HTPC to AMP
Discussion in 'Hardware' started by ringoiom, 2 Dec 2010.
  1. ringoiom
    ringoiom What's a Dremel?
    20 Jul 2010
    Morning Guys,
    I've been asked to spec out a HTPC Build for a friend who wants to run the Audio thru his slightly aged Amp.
    I'm not all that experienced with passing audio through to an amp so was wondering what the best outputs/imputs to use.
    Heres a Link to his Amp...... http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/amplifiers/denon-avr-3805-293461/specification
    He wants as small a unit as possible with Bluray playback and a decent (at least 2TB) amount of storage....
    I was thinking of going with the GA-H55N-USB3 - and I3 but not sure if it will have the requisite Audio connections....
    If one of you could kindly advise me it would be mucho apprciated
  2. saspro
    saspro IT monkey
    23 Apr 2009
    You're going to need to decode the audio in software and output over analogue to the EXT in sockets if you want to get HD audio from bluray
  3. ringoiom
    20 Jul 2010
    Cheers Saspro - which software would you recommend?
  4. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    You could also use the optical S/PDIF as well and output AC3, using the digital optical inputs on the amp. That amp is too old to decode any of the HD audio formats, so that's a non-starter anyway (the 7.1 it talks about is just upmixed 5.1) unless you use analogue inputs like saspro suggests (although I'm not sure whether it has 7.1 inputs or just 5.1 inputs).
    Best option is to get him to upgrade his amp (to something like this) at the same time - that way, you can use the HDMI port on the motherboard to carry sound and video to the amp.
  5. saspro
    saspro IT monkey
    23 Apr 2009
    Total Media Theatre with a half decent soundcard will work fine
  6. ringoiom
    20 Jul 2010
    @ Fibble - Cheers man, ive pointed this out to him - we'll see what he says
    @ Sapsro - Will look into TMT - not used that before (I run XBMC on mine)
  7. saspro
    saspro IT monkey
    23 Apr 2009
    TMT with Win 7 media centre is a great combination.
    If you change amp's go for the 608 or above.
  8. erikduop
    erikduop What's a Dremel?
    3 Dec 2010
    if you want more than stereo from games, etc. Youll need 5.1 analog cables hooked up, instead of spdif. Thats the general idea with the spdif, find a 1/8 to rca, probably mono. and plug into the receiver.
    _____________
    VLC Player
  9. ringoiom
    20 Jul 2010
    Cheers for the input Erik but he's not looking to do any gaming just Music Films etc......
