Small Form Factor Connecting NUC to DVI-D
Discussion in 'Hardware' started by Arboreal, 12 Jun 2020.
  1. Arboreal
    21 Jan 2011
    I am rejigging my office setup so that i can run 2 PCs more easily with the 2 port KVM received from @Fingers66 today.
    The KVM has fixed output cables and the video connection is DVI-D male.
    My 4th gen NUC has either a mini HDMI or mini DP connection.
    I have an HDMI to mini HDMI cable, so was looking for a female DVI to female HDMI adaptor, but they don't seem to exist. Seems no one else is mad enough to need that particular adaptation.
    I could use a DVI to male HDMI connector from stock and buy an HDMI coupler or Startech do a mini DP to DVI female adaptor cable.
    If there are better ways to go, do let me know.
  2. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    Arboreal likes this.
  3. Arboreal
    21 Jan 2011
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Assuming the NUC's mini-DP port is a DP++ port and supports HDMI alt mode (probably yes, every manufacturer sucks at labelling DP++ ports as such), This should do the trick.
  5. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  6. Arboreal
    21 Jan 2011
    Time to investigate DP++...
  7. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Dell 2XWPC DVI To Mini HDMI Adapter Cable
    Available for £8 delivered here.
    edzieba and Arboreal like this.
  8. Arboreal
    21 Jan 2011
    Result!! you star @lancer778544. Thank you sir
  9. Arboreal
    21 Jan 2011
    Dell 2xWPC on the way and an HDMI coupler to give a 2nd alternative connection.
    I’ll update this when I have some results
  10. Arboreal
    21 Jan 2011
    Bought the HDMI coupler today and came home to find the Dell 2xWPC had arrived in the post. For some unknown reason I had it in my head that it was mini DP to DVI...
    Anyway, I have just fired it up and it works a treat.
    Thank you again @lancer778544 , it's an invaluable item for all owners of NUCs with mini HDMI sockets :clap:
  11. lancer778544
    5 Jan 2011
    Neigh bother, glad to be of assistance :)
