Conroe: Best mobo?
Discussion in 'Hardware' started by veryevil, 20 Jul 2006.
  1. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey, Im looking to buy myself a whole new system in the next 2-3 weeks and have decided to go conroe.
    I've got about £1200 to spend and thats for everything down to the case and hard drives
    I'm going for the E6600 and Ati graphics (x1800/1900) probably 2Gb of ram
    However im wondering about what mobo to get? Im looking for watercooled overclocking so good power reg is needed + high FSB
    Im looking to spend no more than about £150 on a mobo tbh
    Any Ideas?
    Cheers
  2. Guest-16
    Guest-16 Guest
    Something i975x based, havent looked at enough conroe boards myself yet to suggest one, sorry. You'll have to double check they support conroe though.
  3. Tim S
    Tim S OG
    8 Nov 2001
    The P5W DH Deluxe is good, but I'd wait for the final revision (which is the one that will be in the shops next week, afaik). Check before you buy too, because if it doesn't have a Conroe-supporting BIOS on, it will not POST.
  4. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    wait a couple more weeks, there will be ATi RD600 boards out soon so you should have a wider range :)
  5. Tim S
    Tim S OG
    8 Nov 2001
    it's more than a few weeks away...
  6. nigelnathan
    nigelnathan What's a Dremel?
    13 Jul 2006
    going conroe
    NVIDIA nForce 590 SLI, thats what I am heading for when conroe is officially released. Obviously this is for nvidia cards.
  7. Guest-16
    Guest-16 Guest
    I'd still get a i975, even if RD600 claims to be an uberclocker.
  8. Tim S
    Tim S OG
    8 Nov 2001
    The only benefit of RD600 for CrossFire is dual PCIe X16 slots and of course I can't for get the ATI/ATI combination. Intel's platform does fine with dual x8 slots though. :)
  9. miceless
    miceless What's a Dremel?
    15 Jul 2006
    Is there a board that will run the Conroe and crossfire two ATI cards?
  10. ch424
    ch424 Design Warrior
    26 May 2004
  11. miceless
    15 Jul 2006
    So its the ASUS P5W-DH Deluxe or the Intel 975XBX?
    Why is it that my local supplier says the Asus P5W DH Deluxe WiFi needs a BIOS update to support Conroe (see here)? Is it a different version or something?
  12. Tim S
    Tim S OG
    8 Nov 2001
    That is the case and you should ask them to update it for you. The latest revision of the board doesn't require that, but I don't think it is in the stores yet.
  13. miceless
    15 Jul 2006
    The site says they dont do it :/
    Guess Ill have to wait a bit.
  14. veryevil
    veryevil Minimodder
    14 Aug 2005
    Cheers Guys theres some great info on the link ch424 thanks.
  15. moddenmania
    moddenmania What's a Dremel?
    18 Sep 2004
    just wait theres more to come I just saw an article today theat there are soon to be quad cores. Just save your money.
  16. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey, TBH whats the point in waiting for quad core, i might then wait for DX10 GFX and the next big thing ive decided that i have the money now and i wont then as im going to uni.
  17. Tim S
    Tim S OG
    8 Nov 2001
    If you're not buying anything faster than an E6600, I agree :)
  18. scq
    scq What's a Dremel?
    4 Mar 2005
    Any ideas on the best MATX Conroe board, or an estimate as to when we might be seeing more being released?
  19. veryevil
    veryevil Minimodder
    14 Aug 2005
    Quick question about Crossfire, whats with the different speed lanes?
    The ASUS P5W-DH Deluxe it says CrossFire (2 X8 PCIe) and 2 PCIe X16
    The Gigabyte GA-965P-DQ6 it says 1 - PCIe X16 1 - PCIe X4 (X16 physical connector)
    Wondering if the gigabyte even supports crossfire (says dual graphics compatible) but doesnt mention crossfire
    Really i wanna know which is the fastest?
    Also would they fit in the Lian Li v1000?
  20. Tim S
    Tim S OG
    8 Nov 2001
    P965 doesn't support CrossFire
