Storage Consumer level backup solutions?
Discussion in 'Hardware' started by Splynncryth, 4 Jan 2009.
  1. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    I'm looking into building a dedicated back up system because as far as I know, there are no consumer level backup solutions.
    Am I wrong? Are there tape backups that don't cost a fortune and handle terabytes of data? What I am seeing are $1000+ USD drives for 400gb which is what I'd consider the starting point of useful capacity.
    It looks like I could get a bunch of hard dives and be able to have a set of drives I can rotate through as if they were takes for less money than a drive and a couple sets of cartridges.
  2. Firehed
    15 Feb 2004
    Tapes are not and have never been consumer-oriented, though of course there's nothing stopping you from using them. I think the best solutions to use, unless you're dealing with tens of terabytes or more of data, are probably much simpler - use Time Machine (or some equivalent for your OS of choice) pointed at a NAS drive, Drobo, RAID system, or whatever you prefer. Or, indeed, an external enclosure for a single drive and weekly snapshots that you rotate.
    Even something like Amazon S3 + JungleDisk is a decent choice if you have decent bandwidth.
  3. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    We have an old PC that we slapped Ubuntu on and added a 320GB drive for a total of 400GB and about £50 tops. Shove it in a cupboard and set up a VNC server on it, then use cwRsync (assuming you're on Windows) and point it at the server. :)
    Also: Build your own Linux server
    cwRsync allows excellent syncing if you can understand it (I can't, my Dad did the programming for me to use it ;)) or DropBox allows syncing over the web I believe, so as long as your server is connected to an always on router or similar that should be ok :)
