Consumer trend towards multi-function TFTs
Discussion in 'Industry News' started by Guest-16, 26 Jun 2008.
  1. Guest-16
    Guest-16 Guest
  2. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Now show me a good 24" TFT with a TV strapped on and ill buy it tomorrow :)
  3. Guest-16
    Guest-16 Guest
    Serious? We were offered a 22" Hitachi with DVB-T tuner for review recently.
  4. Nexxo
    23 Oct 2001
    lf your HTPC uses 200-300 Watts you are doing something really wrong.
    So basically... it's a TV. Kudos on the 3 Watts though.
    Basically the same power consumption as my Pentium Mobile based HTPC. :thumb: And unlike the HD HDR-350Q media center that doesn't need a separate tuner box (add another 10 Watts) so you can record a different channel from the one you are watching on the TV.
  5. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    Definitely, my main computer didn't even load that high.
  6. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    Well my pc is my HTPC aswell so i probbly use that kind of Watts
