News Cooler Master builds 20-core PC
Discussion in 'Article Discussion' started by CardJoe, 2 Mar 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. rhuitron
    rhuitron Bump? What Bump?
    15 Aug 2006
    That's some Massive Folding point for them!
  3. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    Wow.. I had an idea to do something like this years ago, but never had anywhere near the sort of money required to do it. Tis very cool, that's for sure.
  4. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Windows 7(taskbar looks like it?) doesnt have cluster support does it? :>
  5. Icy EyeG
    Icy EyeG Controlled by Eyebrow Powers™
    23 Jul 2007
    How about using 5 VIA VB8001 motherboards (with Nano) together with 5 nVIDIA 9800GT or something like that? Would it be a viable way to build a folding farm?
    Maybe it'd consume even less power that this 5X core 2 quad setup, but I may be wrong... :blush:
  6. Guest-23315
    Guest-23315 Guest
    Now that is cool...
  7. Elton
    23 Jan 2009
    Or even better 5 VIA with 5 HD4850s.
    It'd work out great except the heat output of the cards.
  8. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Here some pictures of the design (courtesy of tweakers.net):
    The system uses custom ATX power convert pcb's. a 12v power goes into the pcb and the pcb connects to the atx power connector of the motherboard.
    They also used very long sata cables (1m) routed from top to bottom and then over to the other side to feed the dvdrom drives and HD's. its a U shape sort of routing.
    The motherboards are cooled with air when the side lid is closed.
    The hardrives are 2.5"
    The watercooling is for the CPU's only a 1 >5 > 1 design
    And a youtube video
  9. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    does anyone know how the liquid cooling system is broken down? it appears that the they have it set up as, Radiator cools fluid, sends the cooled fluid to the two res and from the two res splits to all the cpu blocks, out of all the cpu blocks goes into a manifold which recombines back into one source and then gets pulled through the pump and back to the radiator.
    Or
    One Res is split to the CPUs and then back from the CPU goes into the other res?
  10. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    OMG, geek pr0n! :eeek:
    Ahem... the watercooling. I think that the reservoirs act as manifold collectors. It would be a very inefficient loop indeed in which the reservoir is not the last item before return to the pump. I would suspect that there is a manifold after the radiator that splits the stream.
  11. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
    I have a Blue WaveMaster, and I have to say that I love that case. It is sexy. :D
    That system looks like it would be fun to put together. Maybe my next computer will be a cluster? hahaha
  12. yanglu
    yanglu Hmm...
    20 Aug 2008
    If only you could link the boards together to get them all running the same OS...
  13. Skill3d
    Skill3d Minimodder
    29 Sep 2005
    tidy cabling...
  14. HourBeforeDawn
    26 Oct 2006
    well there is four res so Im thinking that they act as the manifold so it would go Radiator to res, each output of the two res goes to each cpu then out of the cpu going back into the other two res and then to the pump and back to the rad, thats the only way I can think of doing it but remaing effective.
  15. Vigilante
    Vigilante What's a Dremel?
    30 May 2008
    If the boards they used had gigabit ethernet there would be (should be) absolutely no reason why this cannot be used as a cluster, then requiring only a single monitor, keyboard etc etc. Something similar to what the creator of <a href="http://helmer.sfe.se/">Helmer</a> did with 6xQ6600's a little while ago. It wouldn't really be usable as a normal computer, but then again, what would be with 20 cores spread over 5 motherboards?
  16. [USRF]Obiwan
    9 Apr 2003
    The most logical thing to do is to feed the water to the cpu's after the radiator via a manifold. If you look at the video (see above) they actually use a manifold to distribute to all the cpu's. From the cpu's it goes back to the reservoirs and from there back to the pump.
  17. HourBeforeDawn
    26 Oct 2006
    please put a time stamp of where you see this manifold, what Im seeing is 4 sets of res and two appear to be out to the cpus and two appear to be ins from the cpu and thats what I mean by manifold as the res splitting the sourcing going out and coming in. So if you could put a time stamp of where you see the manifold so that I can be corrected or understand what your talking about?
Tags: Add Tags
