Hardware Cooler Master Hyper TX2 & 212
Discussion in 'Article Discussion' started by Tim S, 19 Nov 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Jipa
    5 Feb 2004
  3. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    I was just about to post the exactly same comment Jipa. This cant be good!
  4. kosch
    kosch Trango in the Mango
    12 Feb 2005
    Hmm the 212 looks like they have taken a Tuniq Tower and cut the fins in half and then switched them around.
  5. oddball walking
    oddball walking ...!
    21 Sep 2005
  6. Clocked
    Clocked Yar! It be drivin' me nuts...
    11 May 2004
    I've noticed the bending before on the boards that get used for heatsink testing - I'd put it down to different tensions on different mountings but if the same board is getting bent like that it's only gonna be a matter of time before it breaks (pics please!)
  7. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    @Jipa, i agree! I like the fact that they are smaller than the scythe range of coolers, i just purchased and installed a scythe ninja and its massive, it has cranked my temps down from when i used the intel stock cooler but i had trouble getting the fan in with my ram, nice to see decent temps can be had with a smaller cooler...and the £10 one, no wonder it was given best value! nice review
  8. Jipa
    5 Feb 2004
    But then again.. If you compare the kink on that mobo to the one I saw at Campus Party that's not so big of a deal... However I'd like to point out that whoever made that to the poor mobo on purpose should be punished...
  9. Guest-16
    Guest-16 Guest
    Look how big the graph is and how many heatsink installs I've subjected the same board to! I'll make sure I'll straighten it out in future but I think it's just been flexed too much :blush:
  10. Jipa
    5 Feb 2004
    Bindi: do you reckon it's the pins of the stock 775-cooler that do that or does the same problem appear also with bolt-through mounting? Sure most users change the cooler once or twice, so that's not a big of a deal, but I'm just interested in why mobos do that..
  11. Guest-16
    Guest-16 Guest
    pins mostly - because you have to press from the top without underneath support. With bolts you're meant to tighten opposite ones evenly and stop before it bends.
    You can still bend it back easily enough, and if it's screwed in your case firmly it shouldn't bend as much.
  12. OleJ
    OleJ Me!
    1 Jul 2007
    You have gotten centimeter and milimeter mixed up on page on 1:
    "The build quality is very good and the 90cm sleeve bearing cooling fan is rated at just 22dB. It's designed to draw air in from the sides as well as the front before forcing it inwards - as a result, Cooler Master claims that this gives the effective cooling of a 100cm fan instead."
    Should be "mm" not "cm" otherwise that would be some big ass fans ;)
  13. Guest-16
    Guest-16 Guest
    They are big :hip:
  14. drakanious
    drakanious What's a Dremel?
    12 Apr 2007
    Yeah, but not 90 CENTImeters--that's huge.
  15. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    90cm:eeek::jawdrop: that would NOT fit into my case.
    Thanks for the reviews.
    What was he on when he did that?
  16. Guest-16
    Guest-16 Guest
    Next weeks review: 90m fan.
    Week after: fan guard.. possibly.
  17. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
    I would like to see the temps for the stock Intel and AMD coolers. They are not included in this review or the last one.
  18. christopher3393
    christopher3393 What's a Dremel?
    14 Sep 2007
    This is the first disappointing review I've read on this site in quite a while. The reviewer needs to take a clear stance on the results and make a clear and intelligent comparison with the selected Noctua Cooler. Muddled as is.
  19. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    wholly crap, who would purposefully bend a motherboard
  20. Guest-16
    Guest-16 Guest
    OK.
    There isn't a direct comparison - despite the very similar design, the Noctua is designed for silence and comes with an 800rpm fan, the Cooler Master comes with a 2000rpm fan and has a far greater performance, as well as noise as a result. You can swap out the fans for alternatives, with each other if need be, and they'd probably perform about the same because of it. You don't buy a Noctua expecting ultimate performance, like you don't buy a 212 expecting silence, but both can do either, just not out the box. It doesn't even come with inbuilt fan regulation like you get with the Thermaltakes.
    There are too many options to say, "get this, don't get that" because you can do more than just take it out the box and throw it on a CPU.
    I personally would not buy the 212 because of the noise, I wouldn't get the Noctua either because it's particularly low slung making it incompatible with a fair few motherboards. I'd still get either Thermaltake or stick with my Arctic Cooler Freezer 7 Pro.
Tags: Add Tags
