Cooling Coolermaster Hyper 212+
Discussion in 'Hardware' started by ednismod, 21 Nov 2011.
  1. ednismod
    ednismod Minimodder
    15 Oct 2007
    Hi All,
    Is it safe to cut-off the excess pipes of the CPU cooler? Is it true that there is a special gas inside these pipes? Well, the reason I'm asking is because the CPU cooler doesn't fit on Lian-Li PC-A04 because there is a one or two millimeter excess due to those pipes from the cooler. Your help is very much appreciated.
    Many thanks! :confused: :worried:
  2. Tangster
    23 May 2009
    Safe? Yes. You won't have a working heatsink though.
    Yes.
  3. ednismod
    ednismod Minimodder
    15 Oct 2007
    Crap! That's too bad! Thank you! Does anyone know of a CPU cooler similar to Hyper 212 but with smaller height, like maybe 156mm but has 120mm fans that can be replaced?
  4. Tangster
    23 May 2009
    Gelid Tranquillio rev 2, 152mm tall. Only one fan though.
  5. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    There is no gas inside the pipes of heatpipe coolers - it's a liquid that evaporates as the cooler heats up.
    Still, cutting the pipes is not recommended!
  6. ednismod
    ednismod Minimodder
    15 Oct 2007
    wow. thanks ya all! i may need to sell the cooler and buy a new one. hopefully i will be able to find a descent cpu cooler similar to hyper 212
