Copperhead Firmware
Discussion in 'Tech Support' started by WarningFromSpace, 13 Apr 2006.
  1. WarningFromSpace
    WarningFromSpace What's a Dremel?
    1 Apr 2006
    I am a bit confused on how to update the firmware on my Razer Copperhead, so if any of you have this mouse and have done it I would greatly appreciate and help you could provide.
    Thx
  2. LogicalJester
    LogicalJester What's a Dremel?
    8 Dec 2005
  3. WarningFromSpace
    1 Apr 2006
    After step 5, once I plugged my mouse back in it was not recognized and would not work. Scaling down to select search for drivers I could not select include this location.
  4. WarningFromSpace
    1 Apr 2006
    Thanks for the guide I was going off the instructions on the download page, but after a while of messing around i managed it.
  5. Richard Brown
    Richard Brown What's a Dremel?
    30 May 2006
    Just found this message. Thank you for the detailed procedure. I shall utilize it to see if I can get my Razer to work with WinXP. It works perfectly with my laptop running Win2000.
