Case Mod - In Progress CORE ITX Scratch build full Aluminium machined
Discussion in 'Project Logs' started by CustomRigs, 7 Sep 2020.
  1. CustomRigs
    CustomRigs CallMeCleaner
    8 Dec 2017
    Hello everyone :)
    Here is my worklog to my last Custom Case.
    It gets full built out of Aluminium. Sidepanels get made of black toned 3mm acrylic. Magnetic Top, Front and Sidepanels.
    It has two 240mm Radiators. It is not very very very small but compact. 403x305x135mm.
    Also i designed a small custom DDC reservoir.
    GPU is on the backside and supported up to 328mm.
    Parts a now in the making !
    Mainhardware:
    ASRock B550 Phantom Gaming ITX/ax
    AMD Ryzen 3900XT
    NVIDIA RTX 3080
    Teamgroup 32GB XTREEM ARGB 3600MHz
    Teamgroup 1TB Vulcan G SSD
    Seasonic 750W SFX PSU
    Watercoolingparts:
    TBA
  2. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    WOW If i could render like this i wouldn' t need to mod :thumb:
  3. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
    Loving your Facebook posts, but nothing better than following a build log :thumb: Looking great so far, can't wait to see real metal come to life.
    There's a passing similarity to something I'm working on too, so when I start Asteria Reprise in the new year, honestly I didn't copy you :D
    Is that a 10mm radius in the main body corners? How do you intend to make those bends?
  4. CustomRigs
    8 Dec 2017
    it doesnt get bent ... these are massive cnc milled corners :)
  5. LePhuronn
    6 Oct 2016
    Blimey, how are you achieving that then? Renders do hide seams between pieces so I can't work out where you're joining sections together. If you're milling corners then the renders come across as a huge unibody frame milled from 15cm thick stock :jawdrop:
  6. Cheapskate
    13 May 2007
    Lovely. The only problem would be having the pump up so high. With that and the limited reservoir, it will be hell to bleed.
  7. Defyant Mods
    14 Sep 2004
    Bended? Bent:thumb: Can i ask what on earth will this case/chassis cost mill? is it the hundreds or thousands?
    CustomRigs likes this.
  8. CustomRigs
    8 Dec 2017
    i turn the chassis sideways. should work better :) i just bleed it one time :D i really think of making another reservoir with two DC LT Pumps
  9. CustomRigs
    8 Dec 2017
    i friend of me is milling it for me. he likes it alot and learning more milling technics and cam mangement with my case and other parts he is milling for me :)
    Defyant Mods and Arboreal like this.
  10. Defyant Mods
    14 Sep 2004
    I need to find me some new friends :grin:
  11. MaximumBubbleMods
    MaximumBubbleMods Minimodder
    22 Apr 2020
    The billet required for this :eeek: Your talking hundreds of dollars in raw material alone. I think impossible to machine due to depth of cuts and vibrations/harmonics but REALLY want to see this happen! :rock: Good luck my man!
  12. CustomRigs
    8 Dec 2017
    Sidepanels ready :)
  13. Cheapskate
    13 May 2007
    Pretty. I thought for a second you found a source for 1/4" mirror plex.
    @MaximumBubbleMods - I suspect he's going to round over some 1" x 3/4" bar and add some insets for panel mating.
  14. CustomRigs
    8 Dec 2017
    resevoir is close to get finished :)
  15. lowfat
    lowfat Minimodder
    4 Jul 2013
    Love that side panel pattern.
  16. Cheapskate
    13 May 2007
    Lovely pump top. :D You should opt for stainless steel screws. You can sand the heads flat and polish them.
    Theophilus_Field likes this.
  17. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Cool design, and great renderings. Did you flame polish that res after CNC'ing?
    You've selected the Case Mod category rather than the Scratch build one btw.
