Case Mod - Complete Corsair 570X Crystal Clear
Discussion in 'Project Logs' started by Patuga, 5 Jul 2019.
  1. Patuga
    Patuga What's a Dremel?
    6 Apr 2008
    This is my personal rig, so i wanted something cool but also didn't require a lot of work to put together. I chose the Corsair Crystal 570x and decided to add some RGB to it :p
    After putting everything together, there were a couple of things i didn't like:
    - I didn't like the fact that the Tinted Glass Panels made everything look grey instead of white.
    - The Psu shroud didn't have a cover at the edge so the psu wires could be seen.
    - The Stock fan brackets had some ugly cut-outs and didn't really look very good with rgb fans.
    - The "dark side" was showing. This one was really bad :(
    - I could only mount 2 fans at the top, which looked weird.
    So I decided to add some custom made parts we've been making, to make my build look better. Here's what i added to the build:
    Fullsize Psu Shroud:
    Fan Brackets (top and front). The Front Bracket lowers the fans by 10mm, which lets you install a 360mm radiator at the front and still be able to install 3x 120mm fans at the top, with our custom brackets.
    Motherboard tray Cover:
    Clear Panels for Front, Top and window side, and a matt white for the backside to hide the cables:
    Now the case looks white as it should :laughing:
    Gpu Backplate:
    Finished looks:
    And that's it for now :)
    Let me know what you think of it.
    modd1uk likes this.
  2. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Nice and clean, the only changes I'd really make are the cables. I'd of opted for white & blue cables if it were my own. Something like this...
  3. MADPC
    MADPC Minimodder
    10 May 2020
    I like the back plate!!!
  4. djlegend
    djlegend What's a Dremel?
    9 Jun 2015
    Excellent light effects.
  5. ivory2k19
    ivory2k19 Minimodder
    8 Feb 2019
    Nice and clean i like it :thumb:
