Case Mod - In Progress Corsair 750D "ATOrange"
Discussion in 'Project Logs' started by XTSX, 26 Jul 2015.
  1. XTSX
    XTSX What's a Dremel?
    12 Jan 2014
    Hello guys !
    My new build around a Corsair 750D
    For this mod I’m going to do something sober. The showcase will allow a clear view of the components.
    No big revolution in modding world, I will use the standard gear.
    - Hardware -
    -MB: Gigabyte GA-Z77X-UP7
    -CPU: Intel 2700 K
    -RAM: Corsair Dominator Platinum
    -GC: SLI GTX 1080 Cheesecake
    -SSD: Corsair
    -PSU: Corsair HXi 1000W
    -FAN: Corsair
    - Watercooling -
    -Waterblock CPU : EK-SUPREMACY CLEAN CSQ - NICKEL - PLEXI
    -Waterblock GPU : EK NICKEL - PLEXI
    -Pump : D5 PWM 12 Volts
    -Top/Reservoir : EK-XRES 250
    -Radiator :EK-CoolStream XE 360 / EK-CoolStream PE 360 / EK-CoolStream PE 240
    -Fittings : EK-HD Adapter 12/16mm
    -Tubing : EK-HD Tube 12/16mm Rigide
    -Cooling : EK-Ekoolant Pastel ORANGE
    -Controler : Corsair Link
  2. XTSX
    12 Jan 2014
    Place for some picture:
    Case :
  3. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Good luck and have fun!
  4. XTSX
    12 Jan 2014
    Thank Hukkel !
    No more cuts in the case, here is a good working basis, just the framework :D
  5. XTSX
    12 Jan 2014
    Little Update !
    Waiting about the hardware to get the right size for cutting..
