Hardware Corsair Carbide Air 540 Review
Discussion in 'Article Discussion' started by Meanmotion, 19 Jun 2013.
  1. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Oh, and first custom water cooled build is already done...
  2. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    This is a really tempting case to replace my fairly hot and cramped cm cosmos s. I have to admit I didn't like the look of it until the article said it was about the same height as a prodogy, but now i think it looks awesome. And i'm sure if the cheap plastic front does look cheap plenty of people will carbon fibre it or paint it.
    The only potential problem i can see is the PSU doesn't have a hole in the side panel to draw air through, but i guess a few minutes with a dremel would fix that.
  3. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
  4. Fingers66
    30 Apr 2010
    If you look at the pictures, the PSU is not hard up against the side panel of the case - there is about the same gap as with PSU's that sit on the bottom of cases and draw air from below - about the same as the height of case feet.
    This means the PSU draws it's intake air from the cavity on the right hand side which has an intake grill in the rear.
    I don't think it will be a problem.
  5. Dave Lister
    1 Sep 2009
    Your right its most likely not a problem, but as far as i can tell that side of the case has no fresh air entering it. I'm just being fussy ! and as I said a dremel would sort it out quickly enough if it was a worry.
  6. Fingers66
    30 Apr 2010
    There is a massive vent above the psu when viewed from the rear?
    Sent from my phone...
  7. t5kcannon
    t5kcannon Minimodder
    7 Jan 2011
    I'm extremely tempted too. I have a Silverstone FT02-B for my main system, but think I'll buy this for my secondary system :)
  8. ehume
    ehume What's a Dremel?
    10 Dec 2009
    I'd like to try this with the rear fan removed.
    This is the perfect case for placing under a shelf, from the short height to the front-mounted USB ports. On question -- did the author test those HD SATA cables to make sure they are 6 GB/s?
Tags: Add Tags
