Case Mod - In Progress Corsair Graphite 600T MbK
Discussion in 'Project Logs' started by kier, 11 Aug 2011.
  1. Korvus
    Korvus May contain traces of sanity.
    14 Apr 2011
    Interesting, very tidy job with the top acrylic peice :D Hope the rest is as good.
  2. kier
    kier -----------------
    1 Mar 2011
    Last week a received a very nice package from IT-Service
    Thanks Eddy's ;)
    First the great motherboard: The ASRock Z68 Extreme4
    Two kits Corsair 4 GB DDR3-1600 Kit
    and the beautiful Intel® Core™ i5-2500K
    The big ASUS ENGTX580 DCII/2DIS/1536MD5
    And a nice Sony Optiarc AD-5260S-0B
    I'm not only showing you good products but have also done some work
    The front. I want to give the same looks as the top, with acryl and 2 CM fans.
    The plastic front
    Here I have cut away the middle bar
    Sawn a piece of 5mm blue acryl
    And again the same as the top..........sawn the two fans
    Made the slot for the dvd
    Removed the tape
    But we're not there yet, transparent is not what I want. That's why I have used black film to make small borders, later on with light
    Paste tape again
    Now I have cut out a 5mm line
    Removed all the tape
    Between the DVD and the fan is coming a bay reservoir with the blue acrylic as res window
    That's it for today my friends ;)
  3. bulldogjeff
    2 Mar 2010
    Looking good dude..One question though, have many builds have you got going, it's like a production line. Or do you just never sleep?
  4. kier
    1 Mar 2011
    Thnx, lol got two builds now, I just hate to sit still when I'm waiting for parts ;)
  5. Korvus
    14 Apr 2011
    Looking good. Nice and tidy :D
  6. kier
    1 Mar 2011
    Update !!!
    Did my first cutting in the 600T this week
    The 2 fans in the front
    And the slot for the in/ outlet radiator
    Also drawn the top fans
    And after some dremel power
    Also past black film on the top acryl
    And slide out the same lines as the front panel
    Put everything together
    The fans in the front
    And the outlet from the rad with just enough space to put the fittings in
    The 600T how it's gonna be
  7. Guest-56605
    Guest-56605 Guest
    Spot on kier!!! :dremel:
  8. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    Every single time your mods are awesome. :thumb:
  9. Rai
    Rai What's a Dremel?
    22 Jun 2011
    I look forward to seeing this completed, especially if the inside looks as good as the outside.
    Subscribed.
  10. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    wow! :) as nutman said, quite like your last one, doesn't have to be a bad thing tho ;) just made your style... ....as long as it doesn't mean you build 10-in-a-row :p
    LOVE the build!
  11. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    this mod fits the 600T perfectly!
  12. kier
    1 Mar 2011
    Thanks :thumb:
    Goinig to some nice things inside ;)
    :D:thumb:
    Thanks Bill :clap:
  13. mat0tam
    mat0tam Mr I Dont Know What I Want
    1 Sep 2011
    Kier, your work is amazing (Clicks to website - mouth drops)
    Keep up the inspiration =]
  14. kier
    1 Mar 2011
    Bay res update !!!
    Today I've received my BP reservoir. Nice and small
    Removed the acryl window from the reservoir and marked the holes for the M4 bolds
    Perfect fit ;)
    Cut the lines out of the black film. Same shape as the internal from the res
    And placed it
    Omoobhs likes this.
  15. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Nice, tidy and clean looking:) I like it!
  16. Omoobhs
    Omoobhs One giant fsb hole
    15 Nov 2010
    Really nice modding! :thumb:
  17. Rai
    22 Jun 2011
    What film are you using to cover the blue acrylic?
  18. miahallen
    miahallen Team IRONMODS - World Champions!
    5 Sep 2010
    Awesome stuff kier :dremel:
    Was the mobo sponsored? If not, why choose the ASRock?
  19. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    I'm going to go with sponsored, from IT-Service, but it's actually supposed to be a pretty solid board in the mid-price range of boards. More to that, I'd be interested to see some benching or other testing on that board when you're done...
    Looking good! :thumb:
  20. miahallen
    5 Sep 2010
    Don't mean to sound down on it...it is a good board. But IMO there are better choices (especially for asthetics, which is important to kier I think) so I just wanted clarification ;)
