Case Mod - Complete Cosmos S ITX
Discussion in 'Project Logs' started by biglou, 19 Sep 2021.
  1. biglou
    biglou Minimodder
    10 Jun 2012
    Hello this is my recent build and I want it to share this to the community
    Im biglou from the Philippines
    Here is the case I used
    A cooler master Cosmos S donated by my friends less than a decade ago
    This was pre modded before, rust, dust and corrosion accumulated through the years due to improper storage.
  2. biglou
    biglou Minimodder
    10 Jun 2012
    First thing I want to do is to clean the case
    [​IMG] [​IMG] [​IMG]
  3. biglou
    biglou Minimodder
    10 Jun 2012
    Next is disassembly
    [​IMG] [​IMG]
  4. biglou
    biglou Minimodder
    10 Jun 2012
    measurement and cutting
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Cheapskate likes this.
  5. biglou
    biglou Minimodder
    10 Jun 2012
    test fit for additional adjustment
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Karrek and Cheapskate like this.
  6. biglou
    biglou Minimodder
    10 Jun 2012
    test fit of hardware that I will be using
    measuring and cutting of the outer panels[​IMG]
  7. biglou
    biglou Minimodder
    10 Jun 2012
    after test fitting of the outer panels
    I put secondary measures for adhesion of the cut panels
    [​IMG] [​IMG]
    Using a hobby grade chemical bonding agent a Tamiya Extra cement hehehe
    [​IMG] [​IMG]
  8. biglou
    biglou Minimodder
    10 Jun 2012
    while waiting to cure I placed it on the chassis to adjust more for a decent fit
    Jean R built likes this.
  9. biglou
    biglou Minimodder
    10 Jun 2012
    Cutting of the stand and handle bars
    Sample Stance
  10. biglou
    biglou Minimodder
    10 Jun 2012
    Cutting and fitting of the handle bar
    And I lost the photo for the handle being made hehe
    sample fit for the primed Handle bar
  11. biglou
    biglou Minimodder
    10 Jun 2012
    Making the water channel for the Barrow pump block
    measurements
    [​IMG] [​IMG]
    Finalizing the dimension
    laser cutting
    test fitting
    Manual Tapping
    Bonding using a industrial grade Acrylic cement
  12. biglou
    biglou Minimodder
    10 Jun 2012
    test fitting again
    I also made a mini distro plate with the same process
    again this was a pain in the head while making hehe
  13. biglou
    biglou Minimodder
    10 Jun 2012
    making custom motherboard tray
  14. biglou
    biglou Minimodder
    10 Jun 2012
    apply bondo to the front side cover
  15. biglou
    biglou Minimodder
    10 Jun 2012
    cutting the chassis to give way on my additional mods such as 140mm fans and custom motherboard bracket
  16. biglou
    biglou Minimodder
    10 Jun 2012
    motherboard I/O will be at the top
    Sample mounting
    [​IMG] [​IMG]
    Jean R built and Cheapskate like this.
  17. biglou
    biglou Minimodder
    10 Jun 2012
  18. biglou
    biglou Minimodder
    10 Jun 2012
    making the GPU mount
    sample mounting using a dummy gpu and itx board
  19. biglou
    biglou Minimodder
    10 Jun 2012
    test fitting of all primered parts
    [​IMG] [​IMG]
    Jean R built, neSSa, Karrek and 2 others like this.
  20. biglou
    biglou Minimodder
    10 Jun 2012
    sample paint color
    and it rained
