Case Mod - Complete ⭐ CosmosX Project
Discussion in 'Project Logs' started by SaaintJimmy, 5 Apr 2018.
  1. SaaintJimmy
    SaaintJimmy Staff Lover of bit-tech
    6 Apr 2016
    Hello everyone, today I'm here to present a new project I'll be competing with in the Coolermaster Case Mod World Series 2018.
    Some of you may think this will be like a space-theme given the similarity with the name SpaceX, Elon Musk's airspace company. That's not completely true, as this will be a green/grey/black mod and will only have little to no space references.
    I chose this name because I personally am a fan of everything related to space, and I found "CosmosX" fitting with the mod because, if you look at the front of the C700P, it actually looks sort of X shaped. So I will start from there, shaping the entire mod using that concept, the X lines.
    This is a mod that will go on display at the PC Frog store, so thanks to them for giving me the opportunity to make this project and for gathering two great sponsors together, Coolermaster and MSI.
    Also thanks to Aquatuning and Alphacool which are always available to support me in my projects!
    So let's start by tearing down almost the entire case. Since this is a really beautiful case by default, I found myself in a hard time trying to find an original layout, so the first days was pretty much entirely spent staring at it and trying some mounting for all the brackets.
    This is what I came up with: standard orientation for the mb (even do I can choose to mirror this and do a reverse), which is centered to allow the mounting of two 360 rads on top and bottom. Pretty unique feature, the PSU will be mounted frontally, to allow the bottom rad to be mounted.
    MLyons likes this.
  2. SaaintJimmy
    6 Apr 2016
    Alphacool Eisbecher Helix Green in all their beauty!
    Some cuts to make everything fit properly.
    Acrylic panels at the back and front for a clear view of the internals.
    Reservoirs and pumps mounted on the acrylic panels.
    Now to the side cover and midplate.
  3. Cheapskate
    13 May 2007
    Nice start. At first I was wondering where you were putting radiators, then I saw them. Good Lord, the size of this case sneaks up on you.
    SaaintJimmy likes this.
  4. SaaintJimmy
    6 Apr 2016
    It's time for another big update. This time we'll take a look at the modding of the reservoirs, to make them nicer and sturdier, a bit of internal panelling and the customization of the front panel of the C700P.
    Drilled and tapped some holes on the brackets for the reservoirs
    Then made two panels for top and bottom and started to cut and tap these nice aluminum bars
    Then cut openings for the ports
    And here they are mounted
    Let's get to the front panel! First I cut an opening on it
    Designed and cut a nice touch for the opening
    Then made this details using aluminum U profiles to give it some more character
    As for the internal panelling, I had to cut some pieces of the mobo tray for when I route the cables and make the pass-through holes
    And the last big internal panel is cut as well, now everything is nicely covered and ready for the next step, which is measuring holes for cables and pass-through fittings.
    I also brainstormed a bit on the top panel because I had some difficulties trying to come up with an original design, and figured out I could some watercooling to help myself make it more unique...
    So i cut some pieces of the mounting bracket of the rad first
    (Can you even tell what I cut here? It's all about clean cuts hahaha)
    And this is a teaser of what I'm going to do at the top
  5. SaaintJimmy
    6 Apr 2016
    Here we go with another update: top panel mod and first tube runs!
    A little drawing before cutting
    Cutting and filing done
    To make the top area a bit more unique, I figured something out:
    And now to the internal tubes!
    Cheapskate likes this.
  6. storm-83
    storm-83 Minimodder
    7 Nov 2014
    love the matching angles on the tubing!
    and great work - keep it up :thumb:
  7. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    nice res mount design.
  8. SaaintJimmy
    6 Apr 2016
    Update time! Finally got the MSI GamingX GTX 1080Ti I'll be using for this mod and went on with the modifications.
    Did a thing with the top handles of the C700P... I kept seeing people polishing, brushing or painting them and I just didn't feel like doing the same thing, so I added some aluminum details!
    Then went to back side of the case to figure a design out, came up with this freaky panel:
    Then cut two openings on the side panel (f**k that was tough, that panel is a beast) as well as two pieces of mesh from the original front dustfilter to put them behind those strips.
    Going back to the internals, having the graphics card mounted I could finalize the bottom shroud's pass-through holes, and I also started designing the cutouts to let the air flow (one of two rads is at the bottom)
  9. mnpctech
    21 Apr 2003
    nice update (bookmarked)
  10. SaaintJimmy
    6 Apr 2016
    Thank you very much for the feedback man!
  11. SaaintJimmy
    6 Apr 2016
    Ok I got a HUGE update for you guys, I must have forgotten to update the threads and ended up with 41 pics to share! :D
    Today we'll see the last panels made, a custom lightbar and almost everything of the paintjob. Tomorrow I'm starting the final assembly!
    Midplate vents opened
    Drainport
    Front cover for the PSU cables (because why place it the right way when you can do it reversed?)
    Cover for the GOODRAM ram, which are red and don't fit so well.
    Lightbar making
    Fit and lighting test
    Mods for the back panel
    Now let's get everything ready for the painting phase. Honestly, my least favourite part but at the same time, the one that gives the most eye candy :D
    Very close to the end. Please hold tight :D thank you for following!
  12. Gress
    Gress What's a Dremel?
    10 Mar 2018
    I really love how you studied the X-shapes and the results with the top.
    the lighting of the right-side panel, with only half of the X with light result a little dark, i mean, it doesn't show well your work on the panel, but maybe (probably) it's only my impression.
    However, Nice work! Can't wait to see the final pics! :D
  13. kim
    kim hardware addict
    10 Jan 2016
    great design with the X lines :thumb:, and very accurate hand job, :clap::dremel:, the case is awesome now
  14. SaaintJimmy
    6 Apr 2016
    And finally, the last update before the final pics. This one will follow the final assembly.
    First, bottom radiator and psu
    I made the power cord pass through the bottom dust filter
    Mobo tray cover and top panel with tubes
    Front view with reservoirs and clear panel installed
    Midplate, more panels and pumps mounted
    Soft tubes for the bottom section
    And last but not least, hardline installation
    Then filling, leak testing and air bleeding...
    And it's alive!
    I'd like to take the chance to invite to you to vote for my project in April's Case Modding Update: https://forums.bit-tech.net/index.p...pril-2018-in-association-with-corsair.345005/
    Thank you very much guys! Final pics coming in the next days!
  15. Cheapskate
    13 May 2007
    That came out fantastic. :D I love your tubing runs in particular. -Lots of nice details on every inch of the case.
  16. SaaintJimmy
    6 Apr 2016
    cobalt6700 and _Prometheus_ like this.
  17. Gress
    10 Mar 2018
    wonderful! :hip:
  18. SaaintJimmy
    6 Apr 2016
    Thanks man! Make sure to leave a vote :D
  19. kim
    kim hardware addict
    10 Jan 2016
    for sure you've got my vote too, beautiful, sexy, impressive, a great mod :thumb:
  20. SaaintJimmy
    6 Apr 2016
