Modding CPU Keychain trouble
Discussion in 'Modding' started by mattthegamer463, 5 Oct 2005.
  1. Emon
    Emon What's a Dremel?
    14 Jun 2004
    A drill press is ideal, but if you can get by with a hand drill. You should have drilled the hole first, since you can sink the pins into thick foam or soft wood to hold the CPU in place while drilling.
    GO SLOW. People seem to think that faster is better, IT'S NOT.
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It's a very thin coating of titanium nitride over a normal tool steel bit. :geek:
  3. JamesM
    JamesM What's a Dremel?
    8 May 2005
    ok, just tried this... started with a 1mm bit, then went to 5mm. Both bits are basic titanium coated. Went through easy using a drill press on medium speed.
  4. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    Any pics of the finished P1 cpu James?
  5. mattthegamer463
    26 Nov 2004
    i think my problem is my pathetic cordless 12 volt hand drill im using. im going to give the chip to my stepdad and hell use his drill press to tear through it. that should work fine, according to a bunch of you guys.
  6. Sea Shadow
    Sea Shadow aka "Panda"
    15 Jan 2004
    I tried to do the same but with a drill press and a titanium bit... the bit was bending so I decided to just give up (ended up shattering it with a hammer).
  7. kiljoi
    kiljoi I *am* a computer king.
    13 Oct 2003
    Let us know if it turns out ok!
  8. mattthegamer463
    26 Nov 2004
    ok, im going to his house on friday, so ill have some pics on saturday or so if all goes well.
  9. JamesM
    8 May 2005
    Sorry mate, don't have a cam right now... its up my mothers. I've got lots of chips laying around though, so I might take some wip pics when I get it back :)
  10. mattthegamer463
    26 Nov 2004
    ok, whats similiar to a cpu, but can be drilled through really easily?
    its...(wait for it)
    A CHIPSET!
    i renembered i had cut it from a old mobo with m dremel a while back. 5 seconds under the drill, and now its a keychain.
  11. kiljoi
    13 Oct 2003
    Nice work! Given up on the cpu then?
  12. mattthegamer463
    26 Nov 2004
    of course not! im simply making a computer in keychains, next ill do a laptop HDD platter, and a mini cd, and some other stuff.
  13. xistins
    xistins What's a Dremel?
    10 Oct 2005
    Key chains huh?
    "Is that 300 dollars worth of useless hardware in your pocket or are you just glad to see me."
    Nice idea though. I wouldn't mind having a proc keychain. Anyone have a extra p4 3.6 laying around? :D
  14. SGT_Snacks
    SGT_Snacks What's a Dremel?
    3 Jun 2004
    Amazing how durable AMD CPU's are, just incase a drill were to slip inside the case, while on... ¬.¬
  15. Emon
    14 Jun 2004
    HDD platters used to be coated with some nasty chemicals. I'm not sure if they still are, but you should look into it.
  16. Firefox90
    Firefox90 What's a Dremel?
    14 Jul 2005
    Made a bios key chain. First hole got screwed up so I just flipped it around.
    :rock:
  17. mattthegamer463
    26 Nov 2004
    thats cool, i just might take that idea... except with one of those little mini microchips with the windows built into the cermamic surrounding!
  18. Emon
    14 Jun 2004
    Old SIMM memory modules make great keychains because they already have holes in them for the locking mechanism.
  19. Blackcrown
    Blackcrown What's a Dremel?
    1 Oct 2005
    I made a keychain from a old 486 proc. 486's do drill very easily (especially with a drill pres). But it looks so stupid. :p
  20. Kobalt
    26 Aug 2003
    You guys are giving me great ideas, for those who dont know me i'm a pack rat.When i have a motherboard or anything not working i strip it...completely lol so my point is i have this bag of chips that i've been collecting bios and chips of all kinds even an old mac processor. I think me and my press drill have a date today lolll
    Come to think of it one of those HDD platter wouldn't look half bad hanging off of my truck mirror loll :hehe:
    I'll post pics a bit later :)
