CPU cpu upgrade 1156
Discussion in 'Hardware' started by zpikez, 10 Jul 2011.
  1. zpikez
    zpikez mod-pirate
    25 Jul 2009
    Hey everyone, i'm upgrading from an overclocked i3 to a quad core for an 1156 p55 motherboard. does anyone think its worth the premium for the cheapest i7s or would i be best just going for an i5 760? ill be overclocking either way.
    let me know your thoughts.
  2. zpikez
    zpikez mod-pirate
    25 Jul 2009
    also there's a fair chance another 4gb of memory might get thrown in the mix... if that makes a difference lol =]
    my build as it stands is in my sig.
  3. Lord-Vale3
    Lord-Vale3 His Tremendousness
    1 Dec 2009
    I would just get a 760.
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Check for 750's too. Sometimes you can get these at a bargain especially if you're considering used.
  5. zpikez
    zpikez mod-pirate
    25 Jul 2009
    were those the i7s?
  6. Instagib
    Instagib Minimodder
    12 Mar 2010
    Nope, both i5's. (i5-750 and i5-760)
    Both are quad core chips that'll go to around the 4.0Ghz mark with a good board. No onboard gpu or hyper threading on either.
  7. zpikez
    zpikez mod-pirate
    25 Jul 2009
    sorry i should've known that i was just being sleepy and slow lol
  8. zpikez
    zpikez mod-pirate
    25 Jul 2009
    i've got a good board too, the gigabyte p55 ud2m i think. bit-tech used to suggest it in their buyers guide for their 1156 builds
  9. trig
    trig god's little mistake
    10 Aug 2006
    all the i7 gives you is hyper-threading really, so unless you need another 4 cores (again, hyper-threaded) then i wouldn't bother...
  10. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Don't they have more L3 cache aswell and usually better OC speeds?
  11. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    I've grown to love hyperthreading. You can get a used i7 860 for around the £100 mark, which is the same as what a 920 would go for normally.
  12. zpikez
    zpikez mod-pirate
    25 Jul 2009
    hyperthreading is pretty cool, my i3 performs way above a standard dual core thanks to it. also ive found some i7s on ebay sub £120 so i think that may be where im heading =] thanks for the suggestions everyone. on another note do you think my psu is up standard for my build including an overclocked quad core, its a be quiet! 450w model.
  13. zpikez
    zpikez mod-pirate
    25 Jul 2009
    also lennyrhys, where did you find the aprox £100 860?
  14. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Quite a few 860s have sold around the £100 mark on ebay - it's all about keeping an eye out for the cheap listings. There aren't many listed at the moent, but this one might go for nearer £100 since the seller is accepting offers, and the buy-it-now price of £135 is WAY too steep for this CPU. There haven't been any offers yet, so you could theoretically use that to your advantage - lay down the law, and say £100 or nothing. :thumb:
    PSU-wise, 450W will be fine. I upgraded from 500W but only because I had GTX470 SLI for a short time. Sold the second GPU but kept the ridiculous PSU :D
  15. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    The i7 860 is a great CPU, and can OC quite well, I've managed to get mine to 4.5Ghz (wasn't happy with my voltages or temps so lowered), but I'm sat at 4Ghz all day long now. If you can get hold of one I thoroughly recommend it.
  16. trig
    10 Aug 2006
    yeah, but i'm not going to pay a 50% premium for a little more l3 cache. and no, they don't really oc any better...
  17. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    The i7 is more L3 AND the extra 4 cores of HT. So effectively 8 cores on the CPU. I know, I have one too.
    I got mine to around 4 on my Gigabyte, but someone waved a Big Bang Fuzion under my nose for a price I couldn't resist and I bit. It should be in today. I so can't wait.
    If you can get an i7 for around 100 pounds (American keyboard) then grab it, I'm pretty blasted happy with mine.
  18. fdbh96
    29 May 2011
    L3 cache makes a fair bit of difference (maybe not £50) :)
  19. mars-bar-man
    17 Apr 2009
    Okay, so the people who are saying they don't OC any better/aren't worth the extra, has anyone actually used one of the i7 8xx chips?
  20. trig
    10 Aug 2006
    yep...pretty general question...
