Notebooks CPU upgrade
Discussion in 'Hardware' started by warrmr, 23 Jun 2007.
  1. warrmr
    warrmr What's a Dremel?
    5 Nov 2003
    heres the score i have 2 laptops and acer aspire 3660 and a HP510
    The Acer having an Intel Celeron M 420 1.6ghz
    The Hp has a 2.1ghz P4
    what im after is a list of cpus that will fit the appropriate socket on the motherboard
    the markings on the zif sockets are as follows
    acer ( Socket 478 MT)
    HP (Socket 478 MB)
    now if i put either of those into Google i find not alot.
    i know that they have a very Slightly different pin arrangement on the cpus
    am i right in assuming that socket 478 MT will only fit celeron class cpus
    and the socket 478 MB may have the possibility for a Intel core2 ( not likely as the bios wont support it bit if i could find the appropriate bios flash from the manufacture then it may work)
    incase you got lost in my rambling i want a list of cpus that will fit in the above sockets.
    thankyou.
    edit:- i think i have answered my own question
    socket 478m T is celeron class
    socket 478M B is Pentium 4 M class
    any confirmation of this would be greatly appreciated thankyou
