CPU usage 100% when burning cd? whats wrong?
Discussion in 'Hardware' started by psYCHopath, 13 Jun 2005.
  1. psYCHopath
    psYCHopath What's a Dremel?
    25 Dec 2001
    PC Spec.
    the problem is whenever i burn cd....be it data or audio...the cpu usage hits 100% all the time....i have already installed the Adaptec ASPI drivers. change another cd-rw drive but the problem still presist.
    I dont know wuts wrong with the pc.
    can anyone help me :wallbash:
  2. Brew
    Brew What's a Dremel?
    8 Apr 2004
    Nothing is wrong it your comp, burning takes a significant amount of system resources. Plus your system is a little dated as well. When I had an XP it did the same thing until it was finished.
  3. wharrad
    wharrad Minimodder
    26 Jul 2003
    Thinking about it though, my first CD-Writer was on an old 166+ (Cyrix or something, can't remember) with 32MB RAM - and that worked fine.
    Although it was Win98 and Easy CD Creator.
  4. Austin
    Austin Minimodder
    16 Jul 2004
    :thumb: Your CPU usage shouldn't be anywhere near 100%, even with a slow Duron. Usually this type of problem is solved by updating your drive's firmware but it can also commonly be an issue with the IDE drivers or settings. Redownload the latest mobo drivers, install them and then check that DMA/UDMA is enabled in Device Manager.
  5. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
    enabling dma fixed it when I had that problem which was when I was using 2k
  6. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Check your running DMA mode, not PIO. Check under device manager in windows.
  7. psYCHopath
    25 Dec 2001
    It was PIO then i enable DMA. Shut down the pc....but the problem is still there. I'll try the original drivers that came with the mobo... :wallbash:
  8. psYCHopath
    25 Dec 2001
    its not out dated.... :eyebrow: :grr: :eyebrow:
    found out it was the crappy McAfee 2005 that caused this..when its disabled....all work fine.....
    NO 100% CPU usage.....average 20-25% for wma to cd audio
    and 03-8% for mp3 to cd audio
  9. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    He only said its a little dated, wich is true.
    BTW, Dark Angel pwns. :)
  10. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    I would have put my money on the blue tray... :hehe:
    But it was McAffe eh?
    :p
  11. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    You haven't got anything dumb enabled like auto protection have you? It might have been scanning the files as Nero loaded them into memory to burn them, but that is a just a guess ;)
  12. Austin
    Austin Minimodder
    16 Jul 2004
    :thumb: Norton and McAfee are both over-rated bloatware and I wouldn't recommend them even if they were free. The latest version of AVG is an excellent and FREE antivirus program although there are others too.
  13. psYCHopath
    25 Dec 2001
    sorry for the late reply :rock:
    @ConKbot of Doom
    means the TDK is good?
    yup McAfee.
    @JADS
    Norton has more functions like you can select some folder not to be auto-scaned, like for bt d/l folder
    @Austin
    Yeah norton alwiz cause problem, same goes to McAfee which doesnt detect virus unless u do teh manual scan
    AVG used it last time...will give it a try again...bye bye McAfee
