A/V creating high contast displays (an idea)
Discussion in 'Hardware' started by fartonmyear, 19 Oct 2006.
  1. fartonmyear
    fartonmyear What's a Dremel?
    16 Jul 2004
    so if you've ever taken apart a lcd monitor you know there's this white glowing thing in the back. i was wondering if you would be able to split this backlight pad into sections. let's say you have a video of a sunset in the ocean. ocean on the bottom, sky on the top. if you had a backlight split into 2 horizontal parts you could have the top part glow bright and the bottom glow dim. shouldn't be that hard to make right? so theorhetically you can have a lot of these independent backlight portions or even have one for every couple pixels. bright things would be bright, dark things would be dark. would this work?
  2. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    I believe that's the concept behind the new high dyanmic displays as seen here.
