News Crytek to add AMD Mantle support to CryEngine
Discussion in 'Article Discussion' started by Meanmotion, 20 Mar 2014.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. SimoomiZ
    SimoomiZ What's a Dremel?
    2 Feb 2008
    Should put to bed , the "but can it run Crysis?" question.
    Answer: 'yes, if optimised for Mantle'.
  3. Panos
    Panos Minimodder
    18 Oct 2006
    The biggest benefits are shown to those having any AMD CPU. And from one side is a good thing making the building of medium-high game boxes with those Kaveri CPUs a possibility.
    However if someone has an overclocked i7 (like my 4820K @5Ghz) doesn't matter at all. Rather use an Nvidia card for that matter.
  4. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    AMD cards with mantle seem to be developing a pattern of only coming neck to neck with Nvidia's closest cards. It's all well and good having a superior API but the hardware at least needs to match the competition.
    Anyways it's good to see another developer jump on board !
  5. rollo
    rollo Modder
    16 May 2008
    Its nice in a way but we shall see how it pans out, With them also basically supporting the steam box in both cases now.
    Star Citizen Dev already said Mantle will not be a easy Process for them to do as they are so far into the development process that all engine work is basically completed.
  6. SimoomiZ
    2 Feb 2008
    The current games that offer Mantle support (BF4, Thief) were built with the draw call limitations of DX fully accounted for . If devs can move on from that, as per the Star Swarm demo. rigs with high end CPUs will see big gains too.. current games are developed to use as few draw calls as possible.
    Considering how games have been optimised for DX, the fact Mantle's arrived and matched or bettered D3D in games built for D3D is an impressive start.
  7. SimoomiZ
    2 Feb 2008
    Mantle-esque DX12 will be interesting.
    It's clearly a response to Mantle . MS was probably worried about Mantle going to Linux and the Steam OS and had to respond. It's got to be good for PC gaming.
  8. Parge
    16 Jul 2010
    Citation needed....
  9. SexyHyde
    SexyHyde Minimodder
    24 Jul 2009
    Dude....it's on the internet.....of course it true!
  10. technogiant
    technogiant What's a Dremel?
    2 May 2009
    It helps in any cpu limited scenario....this would apply not only to those using amd cpus but also to high end systems using mutli gpus where the added cpu load they cause may cause cpu limitation even on overclocked Intel cpu's like yours.
  11. Harlequin
    Harlequin Modder
    4 Jun 2004
    £400 R9 290 matching a £1000 Titan black.....
Tags: Add Tags
