Modding Custom Door Panel for TJ07 - Can you help?
Discussion in 'Modding' started by bdigital, 27 Jun 2012.
  1. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Hi everyone,
    I wondered if anyone here knew of someone that could make a custom door for a TJ07?
    I would like to have a door on my TJ with a cut out pattern for the rad at the bottom, instead of the mesh panel that comes with them as stock. Ive got a few ideas but nothing concrete yet.
    I would also want a window cutting out, but nothing too difficult. I can get the painting done myself once the door is made.
    Any ideas? Or suggestions from people who have done it before?
    thank you
  2. Wing Zero
    Wing Zero Ita-sha owner
    28 Apr 2010
    I would suggest that you find someone that does aluminium welding (TIG welding i think is needed) and get yourself a spare set of windowless panels. cut both of them exactly in half, then weld the 2 solid halves together. then go nuts with your window designs
  3. bdigital
    10 Aug 2010
    Hmmm getting 2x windows and cutting them in half... Hadnt thought of that. Thank you! By the way ygpm.
    Any other ideas?
  4. bdigital
    10 Aug 2010
    Bump. Anyone else here made an entire door panel for their tj?
