Case Mod - Complete ⭐ CyberPunk 2077 Mod
Discussion in 'Project Logs' started by Toru, 14 May 2020.
  1. Toru
    Toru Minimodder
    14 Dec 2013
    :happy: I see, that's nice. I painted acrylic back side yellow. So I will try various things with that.
    thanks bro!:thumb:
  2. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    That front shot is sexy! love the shape and the colour :rock:
  3. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Love your job painting !
  4. Toru
    Toru Minimodder
    14 Dec 2013
    Thank you guys!! :grin:
    So, I repainted with the same colors!
    also painted the back side silver!
    back side
    front side
    done haha :dremel:
    Well, The result was what I had expected. This panel opaque enough to cover the under panel and screw.:hehe:
  5. djlegend
    djlegend What's a Dremel?
    9 Jun 2015
    Very good!:thumb:
  6. 4LIEN
    4LIEN Modder
    4 Jan 2020
    A lot better now!
  7. Toru
    Toru Minimodder
    14 Dec 2013
    Thanks guys!:happy:
    Ok, update time!
    I made a rear cover...
    for mobo screws
    and installed front fans
    drill mounting holes in the panels
    for front i/o panel
    reinstalled a custom reservoir also:lol:
    lowfat, Dot_Kappa, ivory2k19 and 4 others like this.
  8. Cheapskate
    13 May 2007
    Oh, yeah...grounding lugs. It's too wet here to bother with them. I forget they exist. :D
    It's looking beautiful. All the other cyberpunk mods are going for the dirty look. You are proving that hyper-clean is good too.
  9. Lambda
    Lambda What's a Dremel?
    28 Feb 2019
    Nice touch with the yellow fans. Did you paint them? Never seen anything than the usual black or white before.
  10. Toru
    Toru Minimodder
    14 Dec 2013
    Thank you! haha:p:
    Exactly, That is hyper-clean style bro:grin::grin::grin:
    Yeah I did it :dremel: Thanks!:thumb:
  11. Toru
    Toru Minimodder
    14 Dec 2013
    So...A lot of time passed since then...:duh:
    Update time!!!:dremel:
    First, CPU installed!!
    and New grease! Bitspower Baircool TP-1 :rock:
    :cooldude:
    Cheapskate likes this.
  12. Toru
    Toru Minimodder
    14 Dec 2013
    and VGA block installed!
    A slight change of plan...because I Couldn't do it well, I ended up not using the acrylic mobo tray
    Drilling holes in a panel so as to use vertical GPU mount
    mounting
    so far...
  13. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Very good! Starting the assembly it's always satisfying!
  14. Toru
    Toru Minimodder
    14 Dec 2013
    Yeah~Thank you!! :thumb:
  15. Toru
    Toru Minimodder
    14 Dec 2013
    DDC pump installed!
    CyberPunk2077 Colors housing:hehe:
  16. Cheapskate
    13 May 2007
    CUTE! :lol:
    The fill ports on those are kinda useless, though. I wouldn't want to open one there with the loop filled.
  17. rchiileea
    rchiileea Minimodder
    11 Jan 2008
    he is Right I have gone for the dirty look too, but this looks really nice too, think we all need a cyberpunk mod meet up when things are better
  18. Toru
    Toru Minimodder
    14 Dec 2013
    Thank you guys!!:hehe:
    tubing and fittings!
    4LIEN and Cheapskate like this.
  19. Toru
    Toru Minimodder
    14 Dec 2013
    Cable Sleeving!
    MDPC-X:rock:
    SSD installed!
  20. Toru
    Toru Minimodder
    14 Dec 2013
    and More LED!!
    Cut acrylic sheet!
    6th street logo installed!
    MDPC-X Cable Sleeves!
    :grin:
    :grin::grin:
    censored_Prometheus_ and 4LIEN like this.
