Case Mod - Complete CYBERPUNK 2077 (yes another one...)
Discussion in 'Project Logs' started by pccustom, 6 May 2023.
  1. pccustom
    pccustom Multimodder
    12 Jul 2017
    Hi guys how are you?
    Here I am with umpteenth MOD on Cyberpunk 2077 this is exactly the third I realize, this game has so many ideas and characters that could be left indefinitely and I don't mind at all, I find this very stimulating theme.
    A customer asked me to make a personalization on a Sharkoon Ca300T case, I will list all the stages of realization and also because not also the difficulties with which I find myself fighting every time I make a mod (for the series everything other moders they don't tell you)
    Yes, because a manufacturer adding details can sometimes reveal itself complicated to the point that the fatteic phrase comes out "but who caxxo made me do it !!
    Some sponsors have added to this project and I refer S3+, Sharkoon, Varese.net with which I opened a sales collaboration.
    Here you can find the video in which I reviewed the Case Sharkoon Ca300T together with other products
    This is the project I intend to make ...
    I will succeed? It starts ...
    Cheapskate likes this.
  2. Cheapskate
    13 May 2007
    Does this mean they will be setting you up with a workshop or tools? Mayhem in speed-mode could be interesting.
    (I accidentally clicked Esperanto in the translation options. :lol: )
  3. pccustom
    12 Jul 2017
    Hi guys as highlighted from the sketch some parts will remain black others will be painted in yellow,
    The case you saw in the Sharkoon review arrived
    The customer really likes this match.
    First completely disassemble the case in all its parts, making sure to remove all the electronic cable components etc. In short, completely naked ..
    The first thing that I will go to do are the transproofing and painted internal panels, generally project the panels on the pc port to measure a photo of the case and then draw us above with a vector program
    In this way I will have the almost perfect measures of the pieces to be cut and can bring them back to caetoncini or adhesive paper for cutting ..
    The interior has more 4 mm painted panels and 5 mm to put the LEDs on the sides, this will give a nice lighting nothing new but one day going to the Lidl supermarket I saw
    The signs of the speakers that had a nice lighting at all intrusive transparent plexiglass with internal white writings, this does nothing but reflect the lights and make them bounce inside the panel
    I wanted to see them better but my wife in the fear that I could disassemble them stopped me ...
    This is the desired overlap of the 2 panels
    In the design of the panels I also organize the graphics and other holes this will help me later when he prepared the masks for the application of the logos and vital lines with the proter from the Taglioper for this customization
  4. pccustom
    12 Jul 2017
    Painting the parts in yellow, very ******* color as it is never 100% covering but you have to give more covers 3 or 4 this to have a homogeneous color
    reassembling
    Dot_Kappa, arduum and Cheapskate like this.
  5. pccustom
    12 Jul 2017
    Hi guys, painting internal panel, it is the bracket that allows the suspension of the video card and partially covers the power supply cases.
    Add graphics .. hope this logo has been hallucinating ...
    Painting of the internal panel cables and controllers after an aluminum gray cover I apply the graphics ..
    LED panel processing always internal
    Once the white painted graphics are added to reflect Eilil as much as possible
    I add the 5 mm wide strips LEDs, making the welds on these was a company, I had to help myself with a magnifying glass ..
    I keep them fixed at the plexi with white vinyl ...
    prova...
    I would say it's ok
    Here is the result ...
    Cheapskate and VictorianBloke like this.
  6. Cheapskate
    13 May 2007
    Awesome work, like usual. :D
    Magnifying glass: Dude! I'm probably younger than you and I use reading glasses and magnifiers for everything already. :lol:
    Edit: OK, you are only 2 years older. You should be half-blind if you were in my shoes. Since you are in the metal generation you should have hearing problems too. ;)
    pccustom likes this.
  7. pccustom
    12 Jul 2017
    And now perhaps the funniest part (cable management aside) assembly here is the components
    MOTHERBOARD: MSI MAG Z690 TOMAHAWK WIFI
    CPU: INTEL i7 12700
    RAM: 32 GB DDR4 S3PLUS
    STORAGE: 2 SSD 480 + M2 48OGB S3PLUS
    GPU: MSI GAMING X TRIO RTX 3090
    POWERSUPPLY:SHARKOON SILENT STORM 850W
    COOLING: SHARKOON AIO S90
  8. pccustom
    12 Jul 2017
    assembling...
  9. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    I have not yet heard that "Intel" has solved the socket problem for the 1700 series. i7 will get quite hot and will require a socket booster plate to be installed. Otherwise the heatsink will not hold properly and the CPU will overheat.
  10. pccustom
    12 Jul 2017
    sincerely I've not had this problem..
  11. pccustom
    12 Jul 2017
  12. censored_Prometheus_
    26 Mar 2019
    Probably not. If possible, run a OCCT stress test for 20 minutes and take a screenshot of the CPU temperature.
    :eyebrow: Curious to take a look.
  13. pccustom
    12 Jul 2017
    thi casemod is for a customer, he will take all work to do for this in the future..
    censored_Prometheus_ likes this.
  14. Cheapskate
    13 May 2007
    Fast and beautiful. :thumb:
  15. miculago
    miculago Minimodder
    25 Oct 2020
    Very nice project! I like the effects that you create with plexi, stickers and lighting the most. :thumb:
  16. pccustom
    12 Jul 2017
