Windows DAEMON Tools and Vista 64-bit
Discussion in 'Software' started by Entropy, 10 Dec 2008.
  1. Entropy
    Entropy le mayo
    22 Jul 2008
    Only a short post, nothing to worry about.
    Can anyone tell me why DAEMON Tools wont work with my operating system? I'm running Vista Ultimate 64-bit, and I downloaded a version which should work, according to this sentence on the download page:
    When I try to mount a drive, it comes up with the error
    So, anyone know where I've gone wrong?
  2. Krikkit
    21 Jan 2003
    Try emailing the Daemon tools people, their help pages are pretty good too. :)
  3. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    works fine for me in vista x64. do you have any other disc emulation software it might be conflicting with?
  4. Entropy
    Entropy le mayo
    22 Jul 2008
    Nope, it's the only one I've got.
    If you're on the same OS as me, could you try downloading the one from the link I showed and see if it works? That is if you aren't already running that one.
    I'll try the help pages in the meantime.
  5. Akava
    Akava Lurking...
    28 Jul 2007
    I'm running the version you linked in your first post of Vista 64 with no problems at all, tried re-installing it?
  6. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    If you can't use it, try Virtual Clone Drive - I can confirm this works with x64, and doesn't seem to throw any problems up
  7. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Make sure that the installer ran with admin priviledges. Also the same after the reboot.
  8. kenco_uk
    28 Nov 2003
    I run the lite version in 64-bit.. works fine.
    Link
  9. Entropy
    Entropy le mayo
    22 Jul 2008
    Oddly enough it's fixed now.
    But in case anyone googled the error message I posted with initially (comes up with this thread as one of the first results) I'll show you how I fixed it.
    1) Reboot your computer
    2) Press F8 while it's starting up to bring up the boot options (with safe mode etc.).
    2) Scroll down to "disable driver signature enforcement" and press enter.
    If that doesn't work, send an e-mail to the people at DAEMON Tools who, as mentioned earlier, are very helpful.
  10. hm500
    hm500 What's a Dremel?
    19 Dec 2008
    i have the same problem. It worked fine and mounted stuff fine after I installed it. But now I get the "DAEMON Tools Pro driver error: -1". I have windows XP. I can't locate the "disable driver signature enforcement" in my boot options (possibly because I have XP not Vista). Can anyone help?
  11. Firehed
    15 Feb 2004
    Wait, you can override the check for signed drivers in Vista 64? WTF?
  12. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Running version 4.09HE SPTD 1.43 here on my Vista 64bit SP1, works 100% fine :blah:
    I dont recall having to diable any driver signiture check, then again it may be possible ive disabled it for previous hardware drivers :S
