Graphics Dead 660TI replacement on a budget
Discussion in 'Hardware' started by escafoxx, 18 Apr 2016.
  1. escafoxx
    escafoxx What's a Dremel?
    19 May 2010
    Need advice on a decent enough replacement.
    Was using a MSI 660ti Twin Frozr III GPU until it decided to die on me last week. Looking for a new replacement. Issue being I need to keep within a budget as I want to save buying something far better until I build a new pc. Top budget is £150 (less would be better), and would like to stick with a Nvidia GPU.
    Suggestions please?
  2. RedFlames
    23 Apr 2009
    well £150 gets you a 950 from the green corner [which would be a touch slower than the 660ti], or a R9 380 from the red corner [which is a smidge quicker than a 660ti]...
    It's that or see what you can pick up second hand...
    EDIT: it seems prices have changed since I last checked... the 950 has come down to 130-140 and if you can stretch another £10, you can pick up a 960 for £150-160
  3. escafoxx
    19 May 2010
    Having a look on Scan I've found a 960 for £153 with 950 ave at about £125. Worth going for the 960 or shall I just stick with 950 until I rebuild from scratch?
  4. Mr_Mistoffelees
    26 Aug 2014
    Buy the 960, then get a good portion of your money back by selling it here, if you get your post count up so you can access the Marketplace.
  5. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
  6. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    If you're interested I've got an Asus GTX 660 ti directcu ii that you can have for £30 + P&P?
    RagingMadman likes this.
  7. RagingMadman
    RagingMadman What's a Dremel?
    6 Oct 2012
    **** that, 150 would get you an old 290X from the bit farming days. ez-pz.
    Buying a pc on a budget, 2nd hand tech is 100% the way to go
    Scratch that,
    do this :
  8. bartiszon
    bartiszon Minimodder
    25 Aug 2010
    Getting a second hand card would be the best option and you won't find a better offer than this:
  9. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    What Buzzons has offered you is fantastic deal. paid £47.50 a few weeks back for a stock GTX 660 non TI version.
    The only reason I had need for a non TI is I wanted an identical card to run SLI and get a cheap performance boost.
