Motherboards Dead motherboard?
Discussion in 'Tech Support' started by pdf27, 29 Jul 2011.
  1. pdf27
    pdf27 What's a Dremel?
    6 Jul 2006
    Motherboard is Gigabyte EX58-UDR3, can't remember the rest of the system offhand.
    PC was running windows backup, and about 12 hours in (having backed up but not finished checking the backup) froze. On rebooding it will not enter POST, fires up for about 2 seconds then turns off and restarts. Nothing on the monitor. I've tried clearing the CMOS and removing the RAM, neither makes any difference.
    Any suggestions beyond it being a dead motherboard and in need of replacement? It's about 2 years old at this point, and I've never really overclocked it so a dead motherboard would be something of a disappointment.
  2. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    PSU would be the next thing to test, if you have a spare one..
  3. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Like neil said, try psu then if that has no effect try removing all peripherals including hdd etc see if you get post. Does your mobo have a safe cmos setting, perhaps a corrupt bios although I don't see how. Usually psu, ram, hdd. Do you get any beep codes our error lights displayed anywhere?
  4. total zombie
    total zombie What's a Dremel?
    2 Nov 2009
    yep , next thing id try!
  5. SuicideNeil
    17 Aug 2009
    Unplug the backup HDD too.
  6. TheBlackSwordsMan
    TheBlackSwordsMan Over the Hills and Far Away
    16 Aug 2009
    If the board is really dead well, you can Still try to bake it.
