Scratch Build – Complete ⭐ Death Box Z
Discussion in 'Project Logs' started by AKMod, 4 Jun 2019.
  1. AKMod
    AKMod Modder
    29 Mar 2018
    Hello everyone,
    I’m AK from Taiwan.
    New Project:
    Cooperation project with ZADAK
    Apex Legends game theme.
    This time using 3D printing plus woodwork to complete.
    Spec:
    INTEL I9 9900K
    ASUS ROG MAXIMUS XI EXTREME
    NVIDIA GEFORCE RTX 2080
    APACER AS2280 M.2 240G
    ZADAK SHIELD RGB DDR4 3200MHz 16GB(8GBx2)
    ZADAK CPU WATER BLOCK
    ZADAK MOAB II WATER-COOLED PC
    ASUS ROG THOR 1200P
    COOLER MASTER MASTER FAN MF120R A-RGB
    LI-HEAT INDUSTRY PCI-E FLEXIBLE CABLE A.TYPE
    Watercooling:
    BITSPOWER D5 VARIO PUMP
    BITSPOWER WATER TANK Z-MULTI 50 V2
    BITSPOWER LEVIATHAN SF 360 4xG1/4" RADIATOR
    BITSPOWER FITTINGS
    Thanks ZADAK Apacer 宇瞻科技 NVIDIA GeForce Taiwan ASUS Republic of Gamers Cooler Master Bitspower 立熱工業 li-heat industry co.,ltd. support
  2. AKMod
    AKMod Modder
    29 Mar 2018
    Create 3D printed image draft.
    neSSa likes this.
  3. AKMod
    AKMod Modder
    29 Mar 2018
    Some hardware photos.
  4. Cheapskate
    13 May 2007
    That is going to look neat. :D
    Also: Holy cow that Zadak distro plate is SWEET. I would have never tried clamping the edges of the plates down like that. Plexi doesn't like being treated rough.
  5. AKMod
    AKMod Modder
    29 Mar 2018
    I really like this design concept haha..
  6. AKMod
    AKMod Modder
    29 Mar 2018
    3D printing starts
    The top part of the Death Box is separated by 16 pieces.
    Drone is partially separated by 40 pieces
    Wingman partially separated 13 pieces
    Thermal Grenade is partially separated by 6 pieces
    It took a long time to polish and fill the part.
    Some of the filling parts use epoxy resin
    Wood box at the bottom of the Death Box
    Cheapskate likes this.
  7. kim
    kim hardware addict
    10 Jan 2016
    wow, eye catching design...
  8. AKMod
    AKMod Modder
    29 Mar 2018
    Thank you man.
  9. AKMod
    AKMod Modder
    29 Mar 2018
    After 3D printing, because you need to make it like wood so can't use repair materials.
    Can only be slowly polished to smooth.
    Painted with wood grain paint.
    kim likes this.
  10. AKMod
    AKMod Modder
    29 Mar 2018
    Polishing is completed, and the primer is applied later.
    After the surface coating is completed, the old treatment is started.
    Need careful shielding, spray separately.
    [​IMG] [​IMG]
  11. Sa mod pc design
    Sa mod pc design Minimodder
    7 May 2019
    Congratulations you are a great modder
  12. Landux
    Landux What's a Dremel?
    21 Jun 2019
    Love the design!
    What program are you using to prepare the 3D sketch?
  13. AKMod
    AKMod Modder
    29 Mar 2018
    Hello, I use Fusion 360 to sketch
  14. AKMod
    AKMod Modder
    29 Mar 2018
    Water plate perforate.
    Heat sink CNC removal
    Spray primer
    Repair work
    Making IO baffles
    Upper cover 3D parts combination
  15. AKMod
    AKMod Modder
    29 Mar 2018
    Appearance combination, sanding and repairing,
    Spray primer.
    Touch switch with Apex Legends - Thermite Grenade, waiting for old processing
    Apex Legends - Drone build up
    The volume is about 530mmX530mm[​IMG]
    The old effect processing is completed
    Combined with water temperature meter and waterway to connect to Death Box Z.
  16. Cheapskate
    13 May 2007
    I saw the leaked finished product on the computex videos. It came out fantastic.
  17. pccustom
    pccustom Multimodder
    12 Jul 2017
    I LOVE IT!!!!!!
  18. AKMod
    AKMod Modder
    29 Mar 2018
    Lol!!! Thank you very much.
  19. AKMod
    AKMod Modder
    29 Mar 2018
    Thank you man.
  20. AKMod
    AKMod Modder
    29 Mar 2018
    Aluminum parts CNC and laser cutting arrive
    Made a logo foot.
    Painting finish box appearance.
    UV printing light board
    Box interior game character UV printing
    Logo painting
    Test internal assembly
    Old effect processing.
