Build Advice Dedicated Football Manager build
Discussion in 'Hardware' started by Dean R, 3 Nov 2013.
  1. Dean R
    Dean R What's a Dremel?
    18 Feb 2010
    I have a friend who wants me to build him a PC for the new football manager game. He will obviously need it for other browsing and word processing but he says he doesn't need it for any other games as he plays xbox. This is the only pc game he plays.
    So taking that into account in thinking of putting the majority of his money into his processor. A bit into graphics. He won't need a particularly great case or motherboard so long as it's reliable. He does need a wireless card as he doesn't have a connection in his room. He's already set up for monitor keyboard mouse from his old pc.
    I'm a bit out of the loop with the latest bargains and top hardware etc so if people could suggest a build for me that would be great.
    His budget is £400.
    Cheers.
  2. KidMod-Southpaw
    28 Sep 2010
    Sounds like he'd be fine using an APU then. :)
  3. Dean R
    18 Feb 2010
    Cool. So what's the difference between socket FM1 and FM2? I'm guessing FM2 is the latest one?
  4. KidMod-Southpaw
    28 Sep 2010
    Yeah, FM2 is definitely the best thing to go with. I'm sure other people will be able to recommend you as to which model.
  5. RedFlames
    23 Apr 2009
    fm1 is the older one for the 3xxx A-series APUs and 6xx series Athlons
    fm2 is the current one for the 4000, 5xxx and 6xxx A-series APUs, 7xx series Athlons and is not compatible with fm1 stuff
    fm2+ is for the upcoming kaveri APUs, they are compatible with fm2 cpus [supposedly]
    Also worth pointing out that the steam version FM2014 works on linux... so if budget is tight you can possibly get away without a copy of windows...
  6. rollo
    rollo Modder
    16 May 2008
    Depends if he wants to watch matches in 3d or not, If not your better trying to build a Intel build, As fm is not multi threaded at all. Still single thread game uses 1 cpu core.
  7. Dean R
    18 Feb 2010
    Really? So the AMD APU would be pointless then? Gonna have to have a redesign. Yes he wants to watch the matches in 3D.
    I was trying to squeeze an SSD card into the build coz that will make a big difference.
  8. rollo
    rollo Modder
    16 May 2008
    Then the AMD apu would be needed unless your buying a dedicated gpu.
    But fm2014 is not multi threaded and will never be. Same engine the stats bit anyway ( basically 90% of the game)
    The only bit thats been upgraded in years is the 3d match engine which looks like fifa 2004 on ps2 at best. Still awful graphics wise.
    Personally stick it on only com and replays of goals.
    Higher single threaded performance you have the faster it will go. If he wants multiple leagues then its even more vital.
  9. Dean R
    18 Feb 2010
    So I'm confused what you're recommending? An Intel CPU and a cheap GPU would be a faster option? I know the graphics are dreadful and would only need a basic GPU.
  10. Dean R
    18 Feb 2010
    I just need the bare minimum graphical ability to run the 3D match engine on max. Apart from that I want speed.
    Can you recommend a build. And do you think an SSD would be wise (as well as an HDD for the rest of his storage) or spend the extra money on a better processor?
  11. rollo
    rollo Modder
    16 May 2008
    Will make 2 builds for you once home you can check from there what best suits.
  12. rollo
    rollo Modder
    16 May 2008
    http://www.scan.co.uk/savedbasket/575734895067480ea420ae4310b38327
    Would be what id buy if it was me. Its a touch over budget but if you dont need windows its under budget.
    Would play FM 2014 better than any AMD option out there due to its single threaded performance.
    You also dont need a HDD if all your doing is playing FM as FM is like 2gb install.
  13. Instagib
    Instagib Minimodder
    12 Mar 2010
    Just a thought; fm will run on Linux now, so you can save £80 there if you're willing to give it a go.
  14. Dean R
    18 Feb 2010
    Yeh I'm sorted for Windows. I've got a copy. Legitimate of course. Cheers for that build I'll consider it.
  15. Dean R
    18 Feb 2010
    Well I think he would still want enough storage for his music. I just mean he doesn't need it for any other games.
    There's no GPU included in that build, would his on board graphics support it?
  16. rollo
    rollo Modder
    16 May 2008
    yes they would be fine for that 3d match engine. Its not a taxing engine any onboard gpu from the last decade would be fine. Only thing you may need to check is the wireless card.
  17. Dean R
    18 Feb 2010
    What would I need to check about the wireless card?
  18. rollo
    rollo Modder
    16 May 2008
    Check its compatable with PCI-E slots not all PCI cards are and I have not had time to check to make sure yet.
  19. Dean R
    18 Feb 2010
    Alright I'll check it out after work. Cheers for all your help.
  20. RedFlames
    23 Apr 2009
    The Card is PCI, the board only has PCI-E slots... you'd need to pick another wireless card...
