Displays Dell 2407WFp developed an issue
Discussion in 'Tech Support' started by TiSwAs, 21 Aug 2010.
  1. TiSwAs
    TiSwAs The Phantom Flan Flinger
    22 Oct 2009
    Hi, my 2407wfp has just developed an issue - half the screen is ok (right hand side) left hand side has line of different colours.
    Any ideas what's gone wrong or how I can fix it - or will it be just as much to replace with a new one?
    Thanks.
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Uh-oh.
    My guess would be that its probably knackered - have you tried with the different inputs? (VGA / DVI etc)
  3. TiSwAs
    22 Oct 2009
    hi, thanks for the reply - to answer your question, i havent as the picture shows it in test mode, i unplugged all inputs and the left hand side was still the saem as if i had an input connected.
    Thanks
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    looks like a matrix problem, can it be rma'd
