News Dell launches ARM-based server range
Discussion in 'Article Discussion' started by brumgrunt, 31 May 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    ARM for all!
    I've always been a bit of a fan of RISC architecture; it always seemed to make more efficient use of clock cycles compared to x86. ARM-powered servers will be a godsend for power consumption and heat, not to mention space. One of these 48-core machines could easily be virtualised into multiple different virtual servers. I realise that you can do that with x86 machines, but the ARM version would use much less power. The article doesn't state how fast each core is, but I know the Cortex A15 can be pretty speedy. Allocate 4 cores per virtual server and - in theory - you've suddenly got one system providing 12 servers.
    Any word on what the clock speed of the individual cores are, or what sort of cooling they need? It would be a pretty incredible prospect if they can survive high-load situations with passive cooling.
  3. Gareth Halfacree
    4 Dec 2007
    1.6GHz - they're Armada XP 78460 quad-core chips.
  4. Byron C
    12 Apr 2002
    Wait...what? Quad-core chips? So one of these machines fully-packed with 48 SoCs has 192 processing cores available? :jawdrop:
    The mind boggles.
    Again, yes I know you can do that with an x86 server, but I doubt that would fit in 3U. Plus an x86 server with 48 processors would eat gigawatts of power before it's even spent two minutes booting.
  5. Byron C
    12 Apr 2002
    Just found some more info on The Register when googling that chip. Apparently each sled, or server node, consumes 15W under peak load; it doesn't state whether that includes the hard disk power consumption, but assuming it does that equates to a total of 180W draw across 12 sleds at peak load. That's less than a PC from 5 years ago - hell, even 10 years ago. Not to put too fine a point on it, but...F*** ME!
  6. ch424
    ch424 Design Warrior
    26 May 2004
    This is completely wrong. They're Marvell ARMADA-XP, not Cortex-A15. And they're ARMv7 so definitely not 64-bit either.
  7. Gareth Halfacree
    4 Dec 2007
    My mistake: they have a 64-bit memory bus, but a 32-bit local bus - I just saw "64-bit." I'll correct the piece. The Cortex-A15 confusion came from Dell's less-than-clear press release in which it singularly failed to actually mention what chip it was using - you'd think if it really wanted to be seen as leading in a brave new market, it'd make a bit more information available at launch...
  8. Byron C
    12 Apr 2002
    Regardless of the specific chip being used, it's still a pretty damn tasty prospect.
  9. ch424
    26 May 2004
    Yeah, looks awesome! As you said, 192 cores in 3U!
    Gareth, the Armada XP is the chip - Armada XP is a core, just like each of the Cortex series and the Scorpion/Krait CPUs in Qualcomm products. Good job on the fix - it's great that bit-tech does corrections, loads of websites are happy to fire and forget with news articles!
  10. Gareth Halfacree
    4 Dec 2007
    I realise that - but Dell's original launch announcement completely fails to name the chip or even the manufacturer - it just says ARM with no other details. I found out it was an Armada chip from Marvell itself and posted the update in the comments - but forgot I'd written Cortex-A15 in the article! :duh:
    I'm always happy to update pieces if there's a mistake or new information - it does nobody any good to have misleading our outdated information published. That's the trouble with the web - everything lives forever..
Tags: Add Tags
