Delta fan for OC?
Discussion in 'Hardware' started by Dash, 3 Dec 2002.
  1. Dash
    Dash What's a Dremel?
    24 Sep 2002
    Intel 2.4B @ 2.6-2.8
    Asus P4PE MB
    Alpha Pal 8942T HS
    Relaybus 7V & 12V only
    Fan = ?????
    Well I am going to oc the 2.4b 400mhz or so and I am getting a alpha pal but I am not sure what fan to get. I want something that will keep it cool when gaming so noise won't be a issue there 12 volt mode and quiet when I am writing reports or studying for finals at night in 7 Volt mode
    I was looking at this
    http://store.yahoo.com/directron/ffb0812she.html
    but its 48.5 dBA at 12v so how loud will it be at 7v?
    also do you think I am going overboard will the delta on a intel system or should I go with another fan.
    :confused:
    Thanks for any help
    -Dash
  2. Will
    Will Beware the judderman...
    16 Jun 2001
    I would take a look at the Mechatronics 80mm (38dBa, 53cfm) as it seems to be the best compromise between noise and airflow :) though it depends on the sort of overclock you're looking at.
    You could probably do fairly well on just a standard Ystech or Antec fan, providing you're not putting too many volts through the cpu.
  3. DJMyst
    DJMyst yeah baby
    18 Jul 2002
    I have the 80mm Vantec tornado, which is rated at 55 dBa and its LOUD. We are talkin hairdryer loud. It keeps the CPU cool, but you have to wear headphones to get the full sound immersion in games. I don't have mine 7v modded YET, but plan too. If you won't be doing any SERIOUS OCing, then the Mechatronics that Will suggested will be fine.
  4. Dash
    24 Sep 2002
    Ok thanks all :clap:
  5. Adam
    Adam Minimodder
    26 Jan 2002
    You might see more benefit by having a quieter fan on your cpu, but concentrating more on your case airflow. For example, in my ClearPC with just a front intake and rear exhaust I was getting temps of 50c full load on a Taisol 760, but when I had the board outside the case with the same hsf the temps rose to 60 degrees!
    EDIT: One bit of advice though, don't buy anything anywhere near Delta loud as you won't be able to stand it after a few days - I couldn't anyway.
  6. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Adam, you just say that because you're a wuss. :p
    Now, my case isn't the loudest on Earth, I'd compare it a 747 engine, and I could probably sleep through it if I wanted to...actually, I have before.
  7. Dash
    24 Sep 2002
    well then I guess I will be getting that Titan Aluminium fan that was reviewed by bit-tech......maybe I will just save up for watercooling later on :)
  8. strossos
    strossos What's a Dremel?
    11 Nov 2002
    you could spend some extra and get a fan controller to keep speeds down bit when u dont need em.
  9. Dash
    24 Sep 2002
    well I have a relaybus for my cpu fan with a 7v to 12v switch but I am not sure how loud the Delta will be at 7V.
  10. Adam
    Adam Minimodder
    26 Jan 2002
    Louder than a quiet fan at 12v pushing more air I'd imagine.
