My first project, DF was just the name that really it seams to be, my casemod ofcourse. But I have a problem, there is no case, so I will build one from acrylic. I have a lotof tools and some goood ideas, so about 15 min you will get some pictures.
As I promised, there will come some pictures. My acrylic panels : some bending : ANd half of my work, the other side will be bent about 10 min its a mobo cover
err mate the link doesnt work but after a little work i got to ur pics the plexi looks gurd how thick is it
Ok , here we go, Ihave finished bending. Ive Drilled 3 holes and 4 to go, for my motherboard, it will be watercooled and soon as VGA arrives(i hope tomorrow) i'll cut out the holes for video card and my PAssive cooled Zalman motherboard nb cooler. But some pics of the half finished product : The sides arent wave ...
umm well thats a tricky one, but just a question are the bends the same because they look all diffrent which might present a problem! jw thanks
which bends, the mbo cover, or the side? all I can say, that they are just what I want, theyre perfectly fitting
YEEEEEY The front and the back side are ready, just I have to saw the back side corner to the right fit... front My super sweet 2x 120 rad Bent acrylic.... I think it rocks Some day i buy aluminium, and cut out some details to, but this is only the beginning... AND I PROMISE THAT ILL MAKE HI QUALITY IMAGES NEXT TIME
Nice job!, well if the bends are exactly what you need then thats gd, might just be the foto, or my eye sight lmao, anyways good job lookin foward to seeing this!
