Cooling Dielectic coolants?
Discussion in 'Hardware' started by Cabe, 15 Dec 2002.
  1. Cabe
    Cabe What's a Dremel?
    14 May 2002
    New pc, means new mods. So my rig will be getting a shiny liquid cooling system.
    However, as its a rather expensive piece of kit (and water short circuit damage is NOT covered by the warrenty) I was wondering about dielectic/non-conductive coolants.
    Mineral Oil springs to mind, but its a lot less viscous (liquidy) than water.
    so, ny suggestions?
  2. geek1017
    geek1017 What's a Dremel?
    6 Aug 2002
    Normal distilled or de-ionized water should do you fine.
    If you really want to be extreem you could use isopropyl alchohol(sp?)
    If you have an unlimited amount of money you could try some nifty stuff from 3M called Hydrofluroether.
    It has been used before in submersion cooling but I don't see why it wouldn't work in a "normal" watercooling setup.
    I don't have the link handy but somebody tried submersion cooling using some sort of transformer liquid stuff.
    Someone else more knowledgeable will surely come along and give you better info.
  3. Cabe
    14 May 2002
    I assumed because Destilled was used in batteries it was conductive?
    if so, thats great, as its dead easy to get hold of.
  4. Transic
    Transic What's a Dremel?
    4 Dec 2002
    That 3m hfe liquid makes the wallet go ouch...$300.00 a gallon...needs to be replaced every 3 months.... :eyebrow:
    Linkie: Hydrofluoroether
  5. Cabe
    14 May 2002
    i would be cheaper to risk it with water!
  6. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    Actually, I thought I read somewhere that perfectly distilled water didn't conduct? That it was impuritys in the water that did the conducting? I'm probably wrong though.
  7. Cabe
    14 May 2002
    if it doesnt, then I win :)
    theres a car garage at the end of my road that has a distiller for making thier own water for use in batteries.
    im sure they'd sell me some
  8. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    im not sure if this helps
    but before cooling a rig with ln2 they always submerse the components in flourenheurt or something of the fact
    perhaps this is what your looking for?
  9. Cabe
    14 May 2002
    looking at the cost there would be no point
    the fluronert needs replaceing regularly, it would be cheaper to risk a board death than pay out more for something that will stop it happening in the *possible* event of a leak
  10. bee2643
    7 Mar 2002
    hrm
    why need replacing regularily?
  11. TetarZ
    TetarZ What's a Dremel?
    16 Dec 2002
    Okay to answer distilled water is dielectric it jus thas to stay very pure (or else you'll get nice fireworks...)
    Checkout
    robotics.net the guys has done someimpressive tests...
  12. pheonix
    pheonix Toot Toot!
    14 Mar 2001
    Yep distilled water is good, no ions, shouldn't conduct alot therefore its alot safer.
    However bear in mind that as soon as it comes into contact with metal, it will start picking up ions, for example from your waterblock
    Theres not alot you can do about it. Just make SURE there are no leaks. Zip ties are good ways of adding more protection against leaks.
  13. TetarZ
    16 Dec 2002
    I would rather use mineral oil. It more disgusting (Imagine the day you'd wanna change your Mobo Yuk!) but you don't get all the hassle from Ions...
    Mind you though I heard it can react badly with some types of plastic (according to wich type of oil you take).Yur PSU might not like it.
    It's how they cool those big transformers in stations (ie:"Transformer oil").
    What are zip tie by the way???
  14. Transic
    4 Dec 2002
