Modding difference in sheet metal?
Discussion in 'Modding' started by elbarto241, 11 Jun 2007.
  1. elbarto241
    elbarto241 What's a Dremel?
    12 Sep 2006
    i was thinking of buying some aluminum sheets to make some panels for my scratch built case. i was wondering what was the difference between 2024, 5052, 6061, and 7075.
    in other words with would be better for a panel. -wielding will not be involved.
  2. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    I've always used 5052 for my panels mainly because its the cheapest for me and the most widely available. I also used 6061 for some of the other panels too and I didn't notice any difference in machining.
  3. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    The numbers identify what specific alloy the aluminum is. The different alloys can have very different mechanical and chemical properties, but for something relatively non-structural like a case, any type will do. Buy whatever's cheapest in your area.
  4. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    yeah, the numbers make a big difference in the stiffness/weight ratio for things like bike frames and baseball bats, but for a flat slab with no real forces applied to it, you can just go with whatever's cheapest
  5. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    yah, material codes stand for alloy composition, temper, heat-treatment and forging process. tolerance and acceptable values also have a tiny bit to do with code designation, and a lot to do with price, such that high grade aircraft aluminum has much tighter tolerances etc than sand cast aluminum. as said though for modding, get what ever is cheapest
    here's an older list of tradenames and composition http://www.csudh.edu/oliver/chemdata/alloys.htm
    and here's a quick break down of ASME alluminum codes just in case you wanted to know http://www.key-to-nonferrous.com/default.aspx?ID=CheckArticle&NM=2
  6. blackerthanblack
    blackerthanblack Minimodder
    17 Sep 2004
    I agree with all the above, for a case any grade should do. The only thing you may need to watch out for is some tempers (identified by a "-T" and a number after the grade) if you are bending your panels, as some may crack or induce stress. These are often more expensive though, so you should be okay going for the cheap ones.
  7. dutchcedar
    dutchcedar What's a Dremel?
    24 Oct 2004
    5052 is easier to bend to a tight radius and is available in thinner sheets.
    6061 is better for machining and is available in heavier plates.
    Those are the two most commonly stocked by metal shops and suppliers around here. Like Sabbath, I can't tell the difference myself, even after using both. As for using either on a computer case, can't see that it matters.
    I'm not sure about the others (2024 0r 7075).
    If the panel will remain flat, just being cut to size for example, any aluminum will work the same as any other.
