Guide DigiMeter - LED System Activity Bar-Graph/Chaser - SOFTWARE v1.7
Discussion in 'Modding' started by acrimonious, 31 May 2004.
  1. modding-monkey
    modding-monkey What's a Dremel?
    29 Jan 2004
    I have the same problem. I’m running xp pro. :wallbash:
    Great guide by the way!!! :D
  2. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    At what stage do you get that error?
  3. modding-monkey
    29 Jan 2004
    well i get the "DigiMeter has encountered a problem and needs to close. We are sorry for the inconvenience." message when i try to run the v1.7 and on the othre 1 i get "Data source is either invalid or cannot be found. System message: a required argument is either missing or incorrect" when i run it????
    :wallbash:
  4. acrimonious
    8 Nov 2002
    That doesn't really make sense, that's Windows for you though I suppose, give me a few days and I'll see what i can do.
  5. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    That's exactly what's happening to me, thanks for the guide, and hopefully once the software's sorted it should be class. :hip:
  6. phuzz
    phuzz This is a title
    28 May 2004
    wow, nice guide, I've been hoarding blue LED's with plans to have a graphic equaliser type thing in the front of my case using a kit from maplin connected to an audio output. But this looks to be a much more useful, can't wait for a version with more LED's.
    (ps, stupid newb question, if a parallel port has 25 pins, why are you limited to 8 led's, is it that only 8 pins are used for signal and the rest are power or whatever?)
  7. acrimonious
    8 Nov 2002
    The port has 8 data lines, designed for transmitting one byte of data at a time. 8 of the pins are just ground and some are inputs, however, there are 4 additional "status register" output lines, but they are more complex to access, but 12 LEDs with no additional complex circutry is in theory possible and i'll start codign the software to access them after i've got these problems with some XP machines sorted out. :thumb:
  8. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    one little warning again, i am sure i've posted this before somewhere on the electronics forum, but be very careful.
    some old motherboards, especually the old ones with overdrive sockets can't source/sink more than 2.4ma.
    a hex buffer would be a simple 40pence solution, that would seriously reduce the risk, and allow more current with safety.
  9. acrimonious
    8 Nov 2002
    True but with your average LED you're only looking at a ~1.3mA current here.
  10. modding-monkey
    29 Jan 2004
    ok thanks!!! :D
  11. dirtbiker
    24 Dec 2003
    Strangely enough it seems to work now. This is version 1.6.0.1.
    Seems like a tidy bit of software, now i have to find me a parallel connector so i can try it... Cheers! :hip:
  12. modding-monkey
    29 Jan 2004
    Yeah the old software works now but not the new.
    Has any one got a screen shot of the new version???
    :D
  13. acrimonious
    8 Nov 2002
    Looks exactly the same, just with a few more items on the list and more in the options menu.
  14. modding-monkey
    29 Jan 2004
    ok!
    well will u be able to sort the new vertion for xp plz??? :cooldude: :D
  15. Guido
    Guido What's a Dremel?
    27 Jan 2004
    Having a problem when running. XP Pro tells me it's the sysmon.ocx file. Can give a screenshot if needed.
  16. Black
    Black What's a Dremel?
    5 Apr 2004
    sorry for my stupid question but i dont know english very well so its a bit difficult to understand that sheme.Here is the question: i have to connect led's positive(+) to port pin (2...8) or negative(-)?
  17. modding-monkey
    29 Jan 2004
    it doesn't matter!!! :D
  18. acrimonious
    8 Nov 2002
    Yes it does!
    You need to connect the LED's Annode (+) to pin 2 - 9. If it isn't the correct way round the LED wont light.
  19. modding-monkey
    29 Jan 2004
    oh yeah my bad!! diode!!! :wallbash: lol
  20. tapius
    tapius What's a Dremel?
    12 May 2004
    ok is there a new link to download the newest version of this software, and also could someone post a open souce version of talking with the paralell port this way in VB please, it would be greatly appricated - i'll just write some lighted fun software for it :)
