Graphics Direct X
Discussion in 'Hardware' started by Carlk, 7 Aug 2004.
  1. Carlk
    Carlk What's a Dremel?
    10 May 2004
    hey,
    how come not all graphics cards are compatable with directX 9? what does directX actuly do?
    thanks
  2. stephen2002
    stephen2002 What's a Dremel?
    23 Sep 2003
    Ok, I'll use the annoying little smily :search:
    But really basically all graphics cards will be compatible with DX9, as in they will work fine with DX9 installed. The question is do they have the hardware to support all of the advanced shaders. It's like asking why dosn't a 32bit CPU support 64bit operations. It dosn't because the hardware isn't there.
  3. Carlk
    10 May 2004
    ok, is there anyway to tweek a none DX9 compatable card to work well with DX9?
    thanks
  4. Piratetaco
    Piratetaco is always right
    15 Apr 2004
  5. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    Read that and you'll understand l33tmodderman's post.
  6. Carlk
    10 May 2004
    k
    thanks
