Windows Disabled startup program keeps coming back
Discussion in 'Software' started by b0ng0, 30 Oct 2011.
  1. b0ng0
    b0ng0 Reddomitlum
    26 Oct 2009
    Well, title says it all really. If I go into msconfig and uncheck it, when I next restart my PC it has enabled again.
    The specific program is called PPS Booster or something like that. I use PPS to stream Chinese TV and I know that this specific booster basically is used to preload stuff when PPS isn't running. Trouble is, that means it's using my bandwidth all the time.
    At the moment I'm having to kill the process every time I start up, but it's quite tedious. Is there a more permanent way to stopping programs at startup?
    (PPS doesn't have to run for this "background" program to activate).
  2. Kernel
    Kernel Likes cheese
    29 Sep 2003
    Stupid question, but it's not in the start up folder is it?
  3. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Try CCleaner - there is an option there not only to disable a startup program but to delete the entry altogether.
    Once in CCleaner, go to Tools > Startup.
  4. b0ng0
    b0ng0 Reddomitlum
    26 Oct 2009
    Nah, only Dropbox in there buddy.:p
  5. b0ng0
    b0ng0 Reddomitlum
    26 Oct 2009
    Thanks! Totally forgot about CCleaner. Will reboot and see if that's worked
    Edit: Yup that worked, thanks!
  6. SirFur
    SirFur PC Gamer and LAzy B0nes
    8 Apr 2009
    CCleaner is the best! :)
  7. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    This! :thumb:
  8. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Awesome, glad to be of assistance. :thumb:
