News Discussion: Nehalem memory details
Discussion in 'Article Discussion' started by CardJoe, 4 Sep 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. biebiep
    biebiep What's a Dremel?
    12 Dec 2007
    I'll skip this one and wait for 32nm nehalem :)
    I've always preferred 'Tocks' over 'Ticks' as Intel likes to call them... And i'm not too confident about first-gen mobo's getting the most out of this one ;)
    But seriously... 14K mb/s for the budget version... The basic-budget version of thet next generation has more than the mainstream version of this generation xD. That's how we like to see it! Gratz to Intel! (omy, did that just sound fanboyish?)
  3. naokaji
    naokaji whatever
    8 Dec 2006
    is the 1066 the actual max speed supported though or is it just intel being scared of going above jedec specs? I was planning to get another 2GB Cellshock 1866 to have 6GB with nehalem, I sure hope 1066 wont be some kind of hard limit.
  4. Tim S
    Tim S OG
    8 Nov 2001
    1,066 is the maximum memory clock for a stock Bloomfield, that's for sure.
  5. bowman
    bowman Minimodder
    7 Apr 2008
    biebiep, tock is Nehalem, tick is Westmere. :)
    Oh well, I'll wait and see. Either Nehalem will be worth the money, or I'll just go for subsequent downpriced Penryn quads.
  6. biebiep
    12 Dec 2007
    Woops my mistake.
    But yeah, Nehalem's first punches are going to have to be very hard ones. Since a Q9650(heck, even a good ol' OC'ed Q6600)+P45 board is a hard-to-beat combo when priced down to make room for Nehalem :p
  7. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    From all accounts, I think they will be very hard punches. The trouble is, like most prize fighters, you won't be able to afford to hire one. :lol:
    (AFAIK The first Nehalem's will be the "Extreme Edition" parts Q4 2008, then the mainstream will come Q1 and Q2 2009).
  8. Faulk_Wulf
    Faulk_Wulf Internet Addict
    28 Mar 2006
    Okay maybe I am retarded, but I thought that only 64-bit Vista could use the max 4GB of memory we have available now. So what's the point of 6GB of memory if nothing can be accelerated by it? Wouldn't 6GB in 64-Bit be as redundant as 4GB in 32-Bit? Or am I missing something obvious here?
  9. The Jambo
    The Jambo Last on the scene
    26 Mar 2008
    Vista 64-bit can handle up to 128 GB of Memory, hence the much needed switchover to x64.
    Join the x64!
  10. seanap
    seanap What's a Dremel?
    2 Nov 2007
    The jambo beat me to it!
  11. seanap
    2 Nov 2007
  12. Sublym3
    Sublym3 What's a Dremel?
    3 Apr 2008
    Other websites reported that Intel is just sticking to Jedec standards, so there is no 'offical' support for faster memory.
  13. p3ri0d
    p3ri0d What's a Dremel?
    9 Jul 2008
  14. woodshop
    woodshop UnSeenly
    14 Oct 2003
    i'm still waiting for the return of the 1:1 cpu memory relationship..
  15. biebiep
    12 Dec 2007
    Mostly in optimized multi-threaded apps, so that means games are less likely to improve...
    Also, the lower L2 cache on nehalem makes it a less optimal for gaming(comparing to Core's massive L2's), so i'm still not convinced that Nehalem will WTFBBQPWN the Penryns in gaming :p
  16. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    Athlons are using 800MHz DDR2 and they have pretty high mem bandwidth. Now that intel has integrated mem controller into CPU, it shouldn't be surprising :)
  17. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    i wouldnt' be suprised if the uptake on nehalem is pretty slow tbh i would much rather buy a q6600 and some cheap 4GB kit of ddr2
    when nehalem is shrunk and ddr3 is cheaper then i might re-appraise
  18. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Easy - underclock your CPU to 1,333 MHz and see how fast it goes.
  19. naokaji
    naokaji whatever
    8 Dec 2006
    64 bit vista (like all other 64bit os's) supports way more than 4 GB, only a 32 bit os will pose a limit.
    there is also the physical limitation of todays mainboards, you have 4 slots on the s775 boards, with 2 GB modules being the biggest ones avalaible (there are bigger ones, but they are a) insane expensive and b) slow).
    Current intel chipsets have a dual channel controller, so its either 2 or 4 modules.
    I went with 4 1GB modules because they oc better than 2 2GB modules.
    Nehalem will have a triple channel meory controller, so its a) downgrade to 3GB or b) upgrade to either 6 or 12.
  20. SuperNova
    SuperNova What's a Dremel?
    13 Nov 2007
    The price could play a big role in this too. 3GB isn't enough for this CPU, so 6GB will be the spot to aim for (bloomfield is an enthusiast CPU after all). The tripplechannel will deliver enough bandwidth for a while, even at 1066MHz so i can understand why they settle for 1066MHz especially when you consider the price on lets say 1600 or higher specced DDR3 modules. 3x2GB @ 1600MHz++ is expensive, you will basically put more money into the memory than you will for the 2.66GHz CPU (with todays memory prices).
    Then you have the problem with many modules at high speeds. 4x2GB DDR2 @ lets say PC8500 isn't exactly stable on the majority of the boards. NO manufacture (from what i have seen) have added this config in their "support-lists". Since you have three channels you have to have in mind that some people will put 6 modules on the board. 6 modules @ 1600+ speeds would probably create some stability issues.
    So the bottom line is that you market the cpu with 1066MHz support which is "safe" at the same time people will lock for 1066MHz memorys which is far cheaper than the once with higher clocks like 1600Mhz. The 1333Mhz seems to be a mystery though since the price difference isn't that big between them. 1333Mhz seems to the a spot where you could get it to work, but i bet intel goes for the "better safe then sorry" approach on a new architecture.
Tags: Add Tags
