Displays Display Resolution
Discussion in 'Tech Support' started by mzee80, 8 Jan 2009.
  1. mzee80
    mzee80 What's a Dremel?
    7 Jan 2009
    My Desktop computer has installed a now somewhat dated Nvidia Geforce 7300G video card. I am contemplating getting a new monitor for which the normal resolution is 1920 x 1080. Can anyone inform if this card will support this resolution and that there is no incompatibility?
    All endeavours to contact Nvidia with this qery have been unsuccessful.
  2. alastor
    alastor Minimodder
    6 Sep 2004
    I'm pretty sure you can add custom resolutions to the Nvidia Control Panel so even if it isn't natively supported you should be able to get it working fine :thumb:
    Just don't try any games more intensive than Solitaire though :p
