Motherboards Dissapointed with mITX boards?
Discussion in 'Hardware' started by silk186, 7 May 2018.
  1. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Just because something isn't technically a premium feature doesn't mean that having more of them wouldn't cost more though. Another example would be a car with 7 seats over 5, the seats aren't a premium item but having 7 over 5 is, hence the additional costs. If you need 7 seats (which the majority of people don't) you'll pay the additional costs to have them.
    I would guess for most users of the mITX platform 4 USB ports is enough, which pushes anything above 4 into the 'luxury' feature set.
  2. Parge
    16 Jul 2010
    I have 7!
  3. Anfield
    Anfield Multimodder
    15 Jan 2010
    Even If we just accept that it then just leads to the next problem, which is that mainboard manufacturers are horrible at offering a decent selection of ITX / mATX boards while they keep carpet bombing the market with ATX boards that are pointless due to the massive PCI-e lane restrictions present with all mainstream CPUs.
  4. Gareth Halfacree
    4 Dec 2007
    To wade in on the hub debate, I use a powered USB 3.0 hub because it actually makes my build neater. Rather than having a shedload of cables running from my keyboard, trackball, scanner, card reader, graphics tablet and so forth to my desktop - cables which will never reach anyway, because my desktop's on the floor and I have a convertible sit/stand desk - I have a shedload of cables running to the hub on the top of my desk, neatly hidden away behind the monitor, and one cable running to the desktop (plus another to a power socket, admittedly.)
    bawjaws likes this.
  5. silk186
    silk186 Derp
    1 Dec 2014
    I was thinking about this a bit more as the hub can be hidden. Still, I would prefer that it is my choice. Especially as I've found in the past the hubs and extension wires have cause issue of devices disconnecting.
    I was thinking on this a bit more, and a usb 3.1 or similar hub should be able to ditch the power cable.
