Modding [DIY] Replacing fan ZALMAN CNPS9700 LED 110mm
Discussion in 'Modding' started by Chile, 24 Nov 2014.
  1. Chile
    Chile What's a Dremel?
    24 Nov 2014
    Hey guys
    This is a simple mod of the cpu cooler ZALMAN CNPS9700 LED 110mm.
    I got this cooler since June 2009, in that time I had a Phenom II X4.
    To use again this cooler in my new rig I had to buy the "ZALMAN ZM-CS5B Clip Support for Intel 1150".
    Well, after easily install the cooler, I realized and remembered some tiny details:
    - The fan has 3 pins
    - That's the reason that the manufacturer included a manual fan controller, the Fanmate2.
    - Without the fan the speed goes “To infinity... and beyond!" making a huge noise, impossible to be controlled by the bios.
    - Also the fan was making now an annoying clicking noise.
    - To finish the picture, the original fan has 110mm. Nice size, easily to replace... ¬¬
    "So, we will have to find a solution", I thought
    And is in that time of great tribulation and suffering that we just can count with the Google god... amen!
    So, this is what I found:
    Modding the Zalman 9500 Heatsink
    http://www.silentpcreview.com/article284-page1.html
    Replacing the fan in a Zalman cooler
    http://tobestool.net/replacing-the-fan-in-a-zalman-cooler/
    Cool.
    The first one give some ideas, but not the solution.
    The second one offer me a closer solution.
    Based on the last one I began with my mod:
    1. Like I don’t have a drill support the way was improvise something similar:
    2. Fan fixed on the bench and ready to cut.
    3. Cutting with the Dremel 561 Multipurpose Cutting Bit.
    4. Done!
    Here a vid:
    ZALMAN CNPS9700 - Fan Mod 02
    5. Taking off the leds. Removing the led mounts first.
    6. Mounts off.
    7. Marking the place to cut
    8. And cutting with a small saw.
    9. Fan off.
    10. Sanding the blades.
    11. Front view.
    12. Rear view. You can appreciate the finest finishing for the leds :p
    13. Cooler mounted and working. Rear view.
    14. From above
    15. Front view.
    This is the list:
    - 01 case fan Cooler Master SickleFlow 120mm Blue LED
    - 01 Dremel 300
    - 01 Dremel Multi-Vise 2500
    - 01 Dremel 561 Multipurpose Cutting Bit.
    - 02 quick-grip Hand Bar Clamp
    - 01 Cordless Drill + High-Speed steel drill bit 2mm
    - 01 Mini hand saw
    - 01 sand paper
    - Others
    Hope you liked. Was not a "pro" job but it’s working.
    Alvaro
