Networks DIY wirelessly extending network
Discussion in 'Tech Support' started by arachan, 24 Jun 2020.
  1. arachan
    arachan What's a Dremel?
    21 Oct 2011
    Hi folks
    Got myself in an annoying home networking position and keen to hear some advice.
    I have a setup with 2 computers which require decent bandwidth. A desktop which is used for gaming and streaming among other things, and a linux server which hosts a bittorrent client, filesharing, plex server, etc. Both of these sit on a desk, previously ethernet'd straight into a router which ethernet'd into my fibre box (ONT). Neither have a wifi card or any way to connect wirelessly. End result was both got 100mpbs down/10mpbs up which is what I was paying for. This setup worked well for me.
    Fast forward to now, I've just moved house and the ONT is on the other side of the house. I've signed up to a 200 down/20 up plan which works great over 5GHz wifi in the same room or ethernet plugged into the router.
    I need a way to get that sweet 200/20 over to my desk. First I bought and tried an ethernet-over-power kit (which I've had success with in the past) but they didn't connect - different circuit breakers, I guess.
    Then I tried setting the router on my desk (which was previously just being used as a switch) to WDS mode, so it intercepts my wifi signal from the router plugged into the ONT and outputs that via ethernet to both desktop and server. The thing is, my desk is far enough away from the ONT that the wifi in this room is poor (tested both on my phone + desktop using the WDS). I'm getting anywhere from 4-40mpbs which is painfully slow and worse - inconsistent.
    So the question - how can I improve signal strength to my desk, preferably up to the 200/20 which I pay for? I can spend some money if I need to but prefer some DIY hack if possible. Slightly salty about shelling out the $100 on the EoP kit for it to just not work.
    Any suggestions or tips welcome, especially if it's worked for you in the past. Happy to provide specifics on model numbers etc if it's helpful.
    Thanks for your time & appreciate your help in advance
    ara
  2. Speedo
    Speedo What's a Dremel?
    8 Feb 2002
    How far is the distance from your entry point (and WiFi) to your desk, how many walls are between, and what sort of walls are they (brick, plasterboard, etc?).
    Can you give some sort of diagram of the floor layout?
    Do you have any sort of budget for a solution?
  3. davie107
    davie107 Linux or Windows???
    18 Dec 2007
    As Speedo mentioned it all comes down to price layout and what you are able to do to the building etc.
    Obviously some cat 6 cables running to your pc's would most likely be the cheapest option, however if you cant route the cables due to walls or not being able to.
    Power adapters are another option, never used them personally however have heard good reviews, however depends on your sockets being on the same circuit.
    Another option would be to look at a mesh kit. I have used the DECO M4 and has served me well, cheap and easy to setup I now use the devices as access points.
    Each M4 has 2x gigabit ports on, allowing you to connect 2 ethernet devices to them. You can either setup as a router or just as your wifi solution. (the master which will connect to your internet connection via ethernet will only have 1 port free to plug devices into).
    Hope this helps, if you can give any more info on your layout etc people will be able to offer better advice/solutions.
