Hi All, Looking for some confirmation from people using ATI 5XXX cards with 120Hz monitors. Simply, do they work together? I have Win7 and a 5870 and am looking to replace my monitor with a 120Hz model. However from a brief google search it appears a tad hit and miss. I'm mainly a FPS gamer but also work occasionally from home. So would need stable gaming 3D (not the 3D glasses version) graphics and 2D desktop. Confused
It will work, just maybe not at 120Hz. I have ran the viewsonic monitor on a 4870 at 60Hz just fine in the past. Why do you need 120Hz if you are not planning on running 3D vision?
I really can't see any reason why it wouldn't work at 120Hz with an ATI card - an Nvidia card is only required for 3D Vision. Remember to use a dual-link DVI cable though as a single-link cable won't support a 120Hz signal.
Well the HD3000,HD4000 series have just had the added support of 120hz in CCC 10.5 HD5000 series support 120hz. Simon
